Jerky gear change from 2nd gear - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 24th, 2002, 03:57 AM
Local Time: 11:55 AM
England
Maybe this is my lack of driving experience, but every time I select 2nd gear and bring the clutch back up ready to apply my foot to the accelerator, the car seems to jerk. I’m finding it very difficult to get a smooth change. I guess this is likely to be my driving style. Any ideas? It's very annoying.
Old Sep 24th, 2002, 04:36 AM
somerset's Avatar
Local Time: 10:55 AM
Funnily enough, I had the same thing - I think it just takes a little getting used to. I've managed to stop it happening now (MOST of the time). Perhaps its a case of introducing a little finesse into the left boot!
Old Sep 24th, 2002, 08:50 AM
England
I'll try for a little more finesse then. Seems I can only get a smooth shift if I let the clutch out very slowly and take it easy with the accelerator. Guess more practice is in order.
Old Sep 26th, 2002, 05:29 PM
England
Cracked it! Combination of smoother release of the clutch and application of more gas as the clutch is brought up.
Old Sep 26th, 2002, 10:07 PM
DaveNagy's Avatar
Local Time: 02:55 AM
It's been my experiance that the finesse is required more in the right foot than in the left. When moving from a stop then yes, you'll need to "feather" the clutch a bit as it starts to bite. But you should be able to do all your other upshifts without much clutch slippage. The key is, of course, to have the revs matched pretty closely. If you have the engine speed matched to what it's going to "require" in the next higher gear, you should, in theory anyway, be able to pop the clutch and feel nothing at all through the driveline.
I understand that the MCS is prone to "holding on" to its revs when you get off the gas. That's unfortunate if true because when upshiftingyou need the revs to drop in order to have the car's road-speed match with the higher gear you've just chosen.
The same goes for downshifts. You should be able to get off the clutch very quickly and still not cause the car to change speeds. (You don't need to use to clutch at all if you're good. I'm definitely not!)
I found these two articles to be interesting:
Shifting Techniques
Heel-toe Downshifting
-Dave
Old Sep 27th, 2002, 05:57 AM
Bilbo Baggins's Avatar
Local Time: 06:55 AM
United States Male View Bilbo Baggins's Space Blue & Silver 1st Gen MINI Cooper S Profile
I have also noticed that if you try and "short" shift it is jerkier. Make sure you are reving the engine up to 3,000 or more before you try to shift. Also, easing off on the accelerator just prior to shifting, not a sudden "lift" mind you, just an easing, will also help smooth things out.
'06 MCS SB/S R84s(Kumho Ecsta AST, summer), R81s(Nokian Haakapiilatta 2, winter)
'02 MCS DS/W (retired)
Old Sep 27th, 2002, 06:35 AM
England
So when taking my foot off the clutch after engaging gear, when should I start to increase pressure on the accelerator? I found that by gently applying the accelerator while simultaneously releasing the clutch made for a smoother shift. I've not driven a petrol car for ten years, hence all the questions
Old Sep 29th, 2002, 11:58 PM
Ahhhhh, that is indeed the question, isn't it.
Timing and practice is everything. Just keep practicing to keep it smooth. As long as you are not slipping the clutch all will be well.
Normal for jerky gear changes with automatics? Christie_sf First Generation Faults & Fixes 2 Dec 31st, 2006 12:21 AM
Jerky gear change 1st -> 2nd purchox First Generation Faults & Fixes 6 Jul 27th, 2005 11:13 AM
2nd gear, chrisorgan First Generation MINI Cooper 12 Nov 7th, 2004 11:27 PM
2nd to 3rd gear change query? Tracie First Generation Faults & Fixes 13 Mar 4th, 2004 03:28 PM
Is your 2nd Gear change a bit awkward ? Quads First Generation Faults & Fixes 7 Feb 24th, 2004 10:28 PM
