Faulty Door Pins? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 15th, 2008, 07:01 AM
Local Time: 10:55 AM
United Kingdom View djwoody's Classified Ads
United-Kingdom Faulty Door Pins?
Hi.
I have a bit of a problem.
When I unlock my car, the passenger side door does not unlock and sometimes it takes two or three presses of the button to open the drivers door.
The same happens when I use the button on the centre console.
The only way I can open the passenger door is by using the handle inside.
Does this sound like a case of faulty door pins or sensors or something else?
Any help would be appreciated including if it is an easy fix and cost...
Chris
Old May 15th, 2008, 11:51 AM
Mighty mini!!'s Avatar
im having the same problem mate. my passenger door pin wont pop up. im finding out today so if i find the problem il let u know ..
dark blue JCW cooper S aero kit,spots.18"Alpina's c/c arches,sat,nav,dvd, Alta induction-pully,bluefin remap
Old May 15th, 2008, 02:35 PM
Local Time: 06:55 AM
United States Male
Sounds like a bad latch mechanism to me.
Old May 16th, 2008, 05:15 PM
found out it was a solenoid in the door that needed replacing, £30 to fix from my local garage.
Old May 16th, 2008, 05:51 PM
Cool. So I don't need to go to a Mini dealer?
I was worrying it might cost a small fortune.
Chris
Old May 16th, 2008, 09:14 PM
well, if its in warranty go there but if not thendo them both. that what im doing anyway.
Door pins cooperJCW First Generation Interior & Ice 4 Dec 21st, 2006 01:05 PM
Just Fitted My 'S' Door Pins :-) zanhar25 First Generation Interior & Ice 8 Dec 21st, 2006 12:54 PM
Flashing LED Door pins Blusox First Generation Interior & Ice 5 Aug 13th, 2005 11:41 AM
Aluminium door pins... (door lock buttons) GTT 280 First Generation Interior & Ice 3 Jan 12th, 2003 06:31 AM
Door lock pins monsta First Generation Interior & Ice 11 May 3rd, 2002 04:25 AM
