radiator fan questions - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 16th, 2008, 03:26 AM
Motoring Along
Local Time: 06:55 AM
United States Male View diptenkrom's Dark Silver & Black 1st Gen MINI Cooper S Profile
first i would like to say that i am new to this forum, but was kind of referred here from NAM.
i am having a problem with my rad. fan
the 50 amp fuse keeps blowing, so i checked it out, and the blades are stuck...
how are the 2 speed regulated, is it a difference on voltage from the resistor? or is it elsewhere. also i am considering an aftermarket fan, i think it is 12" does anybody know what size teh stock fan is before i remove mine?
also it would be helpful to know if the speed is controlled by voltage, as i think it is, then what the voltage is for low speed would be helpful, as i plan to go aftermarket, and want to make sure the lower voltage won't hurt the new fan. i figure it has to be 6 or 9 volts on low speed, and the full 12 on high.
Old May 21st, 2008, 02:03 AM
United States Male
The usual set up is that both speeds are run on 12 volts, there are just two sets of fan windings in the motor and the ECU switches the power from one to the other based on coolant temp.
Tags: , ,
mini r52 radiator condesor and fan in 50???? jpies First Generation Faults & Fixes 2 Mar 30th, 2008 06:02 AM
Need help understanding Radiator Fan Lucas63 First Generation Faults & Fixes 17 Mar 29th, 2007 12:41 PM
Radiator Fan/Overheating (Bentley Service Manual owners especially welcome!) alphamini Maintenance & MINI Care 6 Aug 10th, 2005 07:48 AM
radiator cooling fan problem??? eddieboyII First Generation Faults & Fixes 3 Jul 1st, 2004 09:42 PM
Blown 5 amp fuse to radiator fan Skaboo First Generation Faults & Fixes 5 Aug 19th, 2003 01:49 PM
