Oil leak - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 19th, 2008, 01:04 PM
MiniPetrolHead's Avatar
258.3bhp and 263.1Nm
Send a message via MSN to MiniPetrolHead Send a message via Skype™ to MiniPetrolHead
Local Time: 11:55 AM
United Kingdom Male View MiniPetrolHead's Solid Black & Body Color 1st Gen MINI Cooper S Profile View MiniPetrolHead's Classified Ads
Oil leak
Just a quick one,
has anyone had an oil leak by the drivers side engine mount? just noticed it yesterday so i mopped it up to see if it would re apear, and it has.
What could be the cause of this? i have just had a new supercharger pulley fitted last week.
The car is an 04 Mini cooper S, its one of the 1st face lift cars.
Alex
Old May 19th, 2008, 01:06 PM
DaFlake's Avatar
MMC Member
Local Time: 06:55 AM
Your engine mount has blown a seal and needs to be replaced. This is a fairly standard failure.
Old May 19th, 2008, 01:15 PM
is it an expencive job, and would it be worth replacing it with performance parts rather than standard?
Alex
Old May 19th, 2008, 01:19 PM
DaFlake's Avatar
MMC Member
There are no performance parts that I know of. Replacement is basically the same procedure as the pulley as you have to get the engine off of it. After that, there are two bolts to be removed.
I assume that this is an 05/06 model...
Old May 19th, 2008, 01:28 PM
they are indeed a common failure,upping the engine torque also applies more force on the mount,
There are as yet no stronger mounts ,but engine dampers are available to dampen the forward/aft movement of the engine and poly bushes available with less flex
DaFlake's Avatar
MMC Member
What he ^^ said...
Old May 20th, 2008, 09:27 AM
Well then polly bushes, a new engine mount and an engine damper it is then!
Alex
Old May 20th, 2008, 01:17 PM
You will not be the first or the last to follow this route,makes you wonder why manufacturers dont fit POLY in the first place?
Old May 20th, 2008, 06:09 PM
United States Male
I am not a manufacturer, but knowing the difference between Poly and OEM bushes might tell the tale. Poly is stiff and not as resilient as the OEM, creating vibration and harshness not appreciated by many street car owners. Generally, race cars get poly, street cars get nitrile.
Old May 20th, 2008, 06:11 PM
Local Time: 10:55 AM
United Kingdom Female View supa-dupa-cooper's Chili Red & White 2nd Gen MINI John Cooper Works Profile View supa-dupa-cooper's Classified Ads
I had an engine mount replaced on my 06 ONE under warrenty, its no biggy really, its a common problem
Old May 20th, 2008, 06:34 PM
MINI-Morgan's Avatar
MINI Obsessed...
Makes you wonder why they decided to change the engine mount design so it cant take much torque and break all the time Lucky pre-facelift owners.......
Old May 20th, 2008, 07:21 PM
DrD
DrD
United Kingdom Male View DrD's Pepper White & Black 1st Gen MINI Cooper S Profile
White Cooper engine mount, idle
My late '04 post-facelift MCS is off to the local main dealer in the morning to have the engine mount fixed. It has been leaking oil for a week or so and seems to have failed spectacularly over the weekend - there is oil all over the place and a big puddle on the floor. This seems to be a really poor design fault and there are lots of posts on here from other sufferers....
I'm also having them look at my dodgy idling speed - another fault that no-one seeems to have completely cured.... I do like the MCS but I am losing patience with it - it is back at ther supplying dealer next week to rectify a dodgy paint job on the near side rear quarter. 'Cherished' my @rse!!!
DrD
Old May 20th, 2008, 07:50 PM
Mmm, theres a thought my mini still has 2 monnths left of its cherished warrenty, so instead of buying a new engine mount, im going to try a wheesel a free onne out of my local dealer! haha
Alex
Oil Leak JAMIE1131 First Generation Faults & Fixes 1 May 23rd, 2007 09:21 PM
Oil leak danny milovanovic First Generation Faults & Fixes 2 Jul 8th, 2006 01:09 AM
Oil leak DrJ First Generation Faults & Fixes 8 May 12th, 2005 07:13 PM
Oil Leak MCS_LecBlue First Generation Faults & Fixes 0 Dec 11th, 2002 04:17 PM
Oil Leak frails First Generation Faults & Fixes 6 May 30th, 2002 12:13 AM
