hatch back rattle 2002 cooper - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 25th, 2008, 07:10 PM
Local Time: 12:55 PM
Netherlands
Read lots about dash rattles here. Actually, my dash is the only part of the car that doesn't rattle
Can't seem to find any solution to the problem listed below. Any help would be greatly appreciated.
Thank you!
Hello friends,
I've recently purchased a 2002 Cooper. I love it!
The car seems to rattle quite a bit. Most of the rattling I can live with however the rattling coming from the hatch back on any roads other than smooth highways is way over the top and making me nuts!
As far as I can see there's no way to adjust the pressure in which the hatch closes except for the 2 rubber plugs on both sides of the hatch. After screwing these 2 knobs counter clockwise, the problem is somewhat helped, but the hatch doesn't close flush with the rest of the body.
After taking off the plastic near the lock, I noticed that there are 2 screws to adjust the lock for a tighter seal. They are already at there maximum, so that's not an option either.
The garage that I bought it from said that it probably comes from the rubber seal along the entire frame that was probably impregnated with something that's causing the hatch not to seal correctly. I think this is probably highly unlikely and the garage doesn't particularly want to help me in solving the problem although he did say that another cooper he sold had the same problem and was noisier than my rattle.
Is this a known problem with the 2002 version?
Any help would be greatly appreciated as I'd rather not have to go to the BMW-Mini dealer here in Amsterdam if avoidable.
Thank you very much.
Davidr
Old May 25th, 2008, 07:27 PM
Paul's Avatar
MINI2 No.1
Local Time: 10:55 AM
England Male
A quick fix is to wrap the latch "hoop" in tape, worked for us. Plenty on here, here's a few:
http://www.mini2.com/forum/faults-fi...ch-rattle.html
Old May 25th, 2008, 07:46 PM
Netherlands
Thank you Paul. After my original posting, I saw on the bottom of the screen related subjects and found the above links. Very interesting. I'll do some taping, greasing, and chair checks tomorrow.
One thing I was wondering about. What is the "standard" position for the 2 rubber screw things on both sides of the hatch back. At this point they're almost completely extended. The rattle is a little less but hatch is sticking out slightly from body of the rear end of the car.
I could try turning the rubbers clockwise and building up the latch hoop with tape.
Just wondering if you have any experience with the correct combination.
Going to BMW here for a new latch hoop seems like a potential expensive fix.
Many thanks.
David
Old May 25th, 2008, 08:15 PM
goonerij's Avatar
The wife thinks its hers!
Local Time: 11:55 AM
England Male
Worked for us too.
Old May 25th, 2008, 08:38 PM
Silent1's Avatar
Supercharger Noiseaholic
Send a message via MSN to Silent1
United Kingdom Male View Silent1's Dark Silver & Black 1st Gen MINI Cooper S Profile
Many thanks.
David
The way i set it up was,
screw the 2 rubber stops in just enough so the hatch sits flush, then wrap the hook in quite a bit of electrical tape so it closes fully but feels tight.
Old May 26th, 2008, 10:57 AM
Netherlands
2 wraps with adhesive tape. PROBLEM IS HISTORY
Thanks to all for your advise.
Amazing that I could solve the problem (even if only temporary) with one lousy piece of adhesive tape on the latch hook!
Wrapped up the rear seat door locks too although they didn't rattle.
Now I'm on to the right door rattle.
Love the car any way. Didn't realize they were so popular. There are 3 on my street and they seem to be all over the place.
Old May 28th, 2008, 01:55 PM
Buz999's Avatar
Just been Clubbed!
England Male View Buz999's Dark Silver & Silver 2nd Gen MINI Cooper S Clubman Profile View Buz999's Classified Ads
I sorted my hatch squeak by buying a new thicker latch from BMW cost all of £3 something and looks better than tape.
Old May 28th, 2008, 07:09 PM
mab01uk's Avatar
While your working on the tailgate please check your hinges for lubrication / stiffness on older MINIs or this could happen.............see thread below for easy prevention before hinges and roof are damaged.
http://www.mini2.com/forum/faults-fi...-shifting.html
Old Jan 20th, 2012, 02:23 PM
Local Time: 04:55 AM
This is old thread, but my low mile 04 (29k mile) just developed cracking sound hatch noise. I checked spare and tools, etc must be the hatch. Called dealer for latch as recommended, they wanted $22.50 for a new latch, it has some sort of black rubber coating on it tech says. FYI>
Back Box for 2002 Cooper hufc2002 First Generation MINI Tuning 5 Oct 31st, 2007 12:27 PM
Rattle in the back Richard22b First Generation Faults & Fixes 6 Sep 10th, 2005 06:43 PM
repair your rear hatch rattle toddtoto First Generation Faults & Fixes 7 Jan 31st, 2003 01:14 AM
rear hatch rattle Iron First Generation Faults & Fixes 6 Jan 21st, 2003 06:44 PM
Boot Hatch Rattle Skim First Generation Faults & Fixes 5 Jan 30th, 2002 03:24 PM
