Need an original 05 S pulley - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 4th, 2008, 02:56 AM
Local Time: 03:57 AM
I sold an 05 mini cooper to a friend in Canada and I was unaware that it had an undersized pulley. The engine blew and the dealer won't warranty it because it wasn't stock. Where do I get an OEM pulley and what would the stock diameter be?
Old Jul 4th, 2008, 01:33 PM
MINI One Seven
Local Time: 11:57 AM
United Kingdom Male View M.O.S's Pepper White & Body Color 1st Gen MINI One Profile
OEM pulley from the dealer!
The Original MINI One Seven
Yorkshire MINI Register - PM for details
Old Jul 4th, 2008, 03:41 PM
DaFlake's Avatar
MMC Member
Local Time: 06:57 AM
Even if you get the OEM pulley, you are going to have a few problems. The first is that the OEM pulley is installed using a heat and I don't know of anyone that has successfully re-installed the OEM pulley. Secondly, they have probably made a note of the pulley in their records and thus will continue to deny coverage. Besides, what you are trying to do is deceiving. If you want to help, help cover the costs of repair.
Old Jul 4th, 2008, 04:56 PM
sef's Avatar
sef
United Kingdom Male View sef's Hyper Blue & Black 1st Gen MINI Cooper S Profile View sef's Classified Ads
At the end of the day the pulley alone should not cause the enigine to blow... There must have been other factors too...
Old Jul 4th, 2008, 04:58 PM
DaFlake's Avatar
MMC Member
I totally agree, but once MINI has denied warranty work, the possibility of getting them to move on it diminishes greatly.
Old Jul 4th, 2008, 05:29 PM
minicabrio's Avatar
Soon to be deleted !!
Local Time: 10:57 AM
United Kingdom Male View minicabrio's Space Blue & Silver 1st Gen MINI Cooper S Profile
The only thing you can do is take the car to an independant and try and prove it was not the pulley that caused the failure.
You're going to have a hard job though - at the end of the day, the vehicle has a modification to the engine aspiration system (i.e. supercharger) and the engine has failed prematurely.
Old Jul 8th, 2008, 10:06 PM
No warranty then in US
We thought if we brought it back to the US it may be warrantied (especially with stock pulley). Should it not have warranty if the after-market pulley was any size or is there a tolerance at all?
Old Jul 9th, 2008, 02:28 AM
DaFlake's Avatar
MMC Member
After market pulley could cause problems. Once the car is in the system of having it, you will have a hard time getting it covered. I am afraid that you will have to find an independent mech to repair it.
Tags: , ,
Original Crank/Pulley Ratio tirlibibi First Generation MINI Tuning 0 Mar 17th, 2008 11:20 AM
Original GTT 280 First Generation MINI Cooper S 7 Jun 20th, 2003 01:42 AM
