P1787 & P1698 - MINI Cooper Forum
post #1 of 3 (permalink) Old Aug 4th, 2008, 12:08 PM Thread Starter
Local Time: 07:57 AM
P1787 & P1698
I haven't been able to find much on this problem. Got a 2002 mini with CVT. The car runs smoothly but acts as if its stuck in the equivalent of 2nd or 3rd gear. Also an X is displayed to the left of the gear selection display on the speedo, Like xP or xD, whatever gear is selected. A friend with access to a good diagnostic computer pulled codes P1787-bi-polar stepper motor open circuit, and P1698 - ECU malfunction.
Online I have found references to a transmission control unit also called a GIU, but the descriptions of where it's located have been inaccurate or unclear. Does anybody know where it's located?
I have found what I think is the ECU in a slot on the left side of the battery box, which is where one desription said that the GIU was located. Other pictures show the GIU mounted on a bracket, but no location is given.
i'm just guessing, but the stepper motor is probably inside the CVT, and does the "shifting". What I need to know is how to determine if the problem is in the actual stepper motor, of if it' s an ECU or GIU problem.
ratfink77 is offline
post #2 of 3 (permalink) Old Aug 4th, 2008, 11:54 PM
mab01uk's Avatar
Local Time: 11:57 AM
Quoted: 1 Post(s)
The GIU (Automatic Transmission Control Module) is situated under the dashboard up above the brake pedal, bolted to brake master cylinder flange. (A7000 on circuit diagrams). Hope this helps
mab01uk is offline
post #3 of 3 (permalink) Old Aug 5th, 2008, 02:13 AM Thread Starter
Found the solution
Mini Cooper Transmission Relearn Procedure
If the gear selection display on your Mini Cooper has an x before the gear selected,
like xP or xD or xR, then you need to run this procedure.
The usual cause of this is a dead or disconnected battery for a long period of time.
First make sure you have a good battery that will hold a charge or fix the charging
system problem.
Get the car someplace where you will be able to drive for a mile or two without
interruption on a fairly level road.
Follow ALL steps and don't skip anything.
Clutch Adaptation
1. Begin with a cold engine and start the car. Shift to N for 10 seconds, then shift
to D for 10 seconds.
Shift to P. Display says xP.
2. Repeat the following ten times. Shift to N for 3 seconds, then shift to D for 3
seconds.
3. Repeat the following ten times. Shift to N for 3 seconds, then shift to R for 3
seconds.
Step-up Ratio Adaptation
1. Accelerate vehicle to a speed greater than 80 km/h. Don't be afraid to go above
the redline on the tach for a few seconds. At this point the car may buck and snort
a little as it tries to get into a higher ratio. As soon as it settles into a higher
gear and the revs are above 4500, rpm let off the accelerator quickly. Don't
gradually let off.
Allow the car to decelerate naturally and you will feel the ratio changing as it
slows to nearly a stop. Do not use the brakes to stop.
You will probably have to repeat this speed up and slow down procedure at least two
or three times until the x is no longer displayed. Each time you will notice that
you are able to go faster. Make sure to get the rpms above 4500 each time.
2. Stop the car and repeat steps 2 and 3 of the Clutch Adaptation procedure to setup
hot transmission clutch values in the computer.
3. Turn off the ignition switch completely.
Now you can start the car and drive normally. Do some aggressive driving and some
normal driving to give the computer a wide range of values to work with.
If your display now shows E in front of the gear selection display, or the car never
"shifted" to a higher ratio during the Step-up Ratio Adaptation, you have other
problems.
Tags: , ,
  LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-faults-fixes/160678-p1787-p1698.html
Posted By For Type Date
Everything about p1698 - Yahoo! Glue This thread Refback Mar 23rd, 2009 01:30 AM
Automatic 2003 Mini Cooper wouldn't start and codes P1698 & P1787 were shown. Tyna Welcome New Members 2 Nov 12th, 2013 06:47 PM
