Jerky CVT Gearbox - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 3rd, 2002, 05:01 PM
Local Time: 06:59 PM
Hong Kong View ar75's Chili Red & White 1st Gen MINI Cooper Profile
Jerky CVT Gearbox
Whenever I pull the shift lever from P to D position, my MINI will jerk, just like another car giving a bumper kiss from rear. The dealer said that it was because I drove between 2000 to 3000 rpm all the time and the computer had programmed my driving habbit. Could anybody help?
Old Oct 3rd, 2002, 05:50 PM
cooper4us's Avatar
Local Time: 05:59 AM
United States View cooper4us's Pepper White & Black 1st Gen MINI Cooper Profile
I would think is normal behavior.
'02 MINI Cooper CVT
Old Oct 4th, 2002, 02:26 AM
Sejanus's Avatar
MINI2 Global Moderator
Local Time: 03:59 AM
United States Male View Sejanus's Chili Red & White 1st Gen MINI Cooper Profile
Re: Jerky CVT Gearbox
I do a lot of freeway driving so I'm usually running around 3,000 rpms, but my car hasn't picked up any such computerized habit. It goes from P to D quite smoothly.
Old Oct 16th, 2002, 08:16 PM
RedBackFur's Avatar
Send a message via Yahoo to RedBackFur
United States Male View RedBackFur's British Racing Green & White 1st Gen MINI Cooper Profile
My CVT is a bit jerky at stoplights at times as well. Seems to happen when the Air Conditioner is on, which, is all the time since I have the climate control. (usually stops when I turn off the compressor).
It feels like someone is bumping the back of the car. If it is really bothering me, I just put it in Neutral.
My only concern is if it is prematurely wearing out the clutch (Remember no torque converter on CVTs!)
2002 Cooper . My CVT Transmission Self-destructed at 89,500 miles
Old Oct 17th, 2002, 04:35 PM
I also worry about the gearbox, so I'll drive my car back to the dealer next week to check it out. Results will be posted in due course.
Old Oct 20th, 2002, 04:29 AM
Local Time: 07:59 PM
Japan
Smile Re: Jerky CVT Gearbox
Hi,ar75
My mini have same problem.
However, I know solution.
This is the defect of a CVT program. The fixing method is making the learned program reset and re-learn.
The shock from N range to D range is disappears by resetting a CVT program.
The dealer should know the operation procedure of computer re-study.
In Japan, many users have solved by this method.
Thank you
Old Oct 21st, 2002, 05:28 PM
Kan2,
Thank you for your information. I'm too busy to get back to the dealer. However, the dealer also told me the problem could be solved by resetting the computer which had learnt my driving habit of keeping the rpm between 2k and 3k. They said that the gearbox would be smooth had the computer been reset but the same problem would appear again if my driving habbit unchanged.
Regadrs
Old Oct 21st, 2002, 08:16 PM
Japan
Reset and re-study
You are right.
Even if it resets at once, there are some persons in whom the again same condition appears.
However, this is the defect of a program. An important thing is the method of re-study.
It is important to be manually in a dealer and to perform re-study correctly not only reset but after that.
This manually memorized process is defined in manual(actually operated MINI).
This study procedure is quite complicated.
Old Oct 23rd, 2002, 12:01 AM
To obehave,
The idle is about 900rpm. It's OK, right? My best friend, a service manager of European car dealer, said that the gearbox of my Mini was abnormal. I'm sure that driving a car with the rpm between 2000 and 3000 is a normal behaviour. How come a normal behaviour will bring about abnormal response.
To Kan2,
I would be grateful if you could post more information regrding "re-study". How does it work? Thanks.
Old Oct 23rd, 2002, 10:14 AM
Japan
CVT?@Reset
The reset method in the tester which a BMW dealer.
1. Diagnose.
2. Selection of function.
3. Service function.
4. Drive system.
5. CVT transmission.
6. Go into a test plan.
7. Original test plan.
8. CVT transmission exchange / study.
9. Reset study.
10. Clutch study (D range and R range 10 times).
11. In-variable-speed ratio study (0-80km running test).
* Reset displays X on the left of a shift position in a speedometer. (X XR, XN, XD)
*?@Go back and forth [ learning a clutch and ] between D range and N range ten time , between?@R range and N range ten times (an in-variable-speed shock improves certainly).
* In order to perform in-variable-speed ratio study, accelerate to 80 km/h first, loosen an accelerator after that, and reduce engine rotation. (About 20 - 30 minutes also of these things are also in this work) .
However, D range shock may occur again for the defect of CVT programming.
Old Oct 23rd, 2002, 12:59 PM
kan2,
It's very complicated indeed. By the way, how can you get those information? Have you got a service manual from the dealer? If so, members of this site will be happy enough if you can post it in the forum.
I will get back to the dealer tomorrow to have the gearbox, rattle within the doors and the seatbelt housing and rough idle (A/C switched on) fixed.
Old Oct 23rd, 2002, 10:54 PM
Japan
re:jerky CVT gearbox
To ar75
I'm sorry. I got to know the information on a procedure with mail.
Therefore, I do not know the exact contents of a manual.
Old Nov 5th, 2002, 12:09 PM
I got my car back on 25 October. The dealer said that they had reset the gearbox and it seemed OK. However, the same problem emerges again 10 days later (only 300 km had made). I doubt about the build quality of the car as well as the service quality of the dealer.
Moreover, the dealer also replaced the "steering box", the exact wording they told me, due to oil leakage.
What a "BMW" car?
Old Nov 5th, 2002, 09:06 PM
Japan
Is it for only ten days?
Probably I think that it has the bad program which is a basis.
I reset CVT gearbox today.
Later, I will also report here.
  #15 (permalink)
Old Nov 12th, 2002, 04:12 PM
Kan2,
How is your baby now? Hope that the CVT is going alright. The service manager of Mini and a senior technician tested the car with me last Friday. They said that they had to check with the manufacturer and the ECU update CD#31 might be helpful to solve the problem. I'm now witing for their reply.
Regards
'06 Cooper is a little herky jerky! Snuff General Discussion 2 Jul 14th, 2006 02:12 AM
Herky-Jerky Driver's Window NearlyNN First Generation Faults & Fixes 4 May 27th, 2005 10:32 PM
Hesitation of CVT Gearbox or Engine? ar75 First Generation CVT & Automatic 4 Jun 27th, 2003 04:40 PM
Price of CVT Gearbox in UK dyfrigroberts First Generation CVT & Automatic 3 May 8th, 2002 02:09 PM
