| Help! Oil light at low revs Hello, can anybody help me please? Changed the oil and filter on my 53 plate Cooper S last weekend and today, the oil light decided to come on. It only lights up when it is warm and idling, as soon as I increase the revs, the light goes out. Found out today that I was sold the wrong oil... lovely Halfords staff gave me semi-synthetic instead of fully. So dropped the oil and replaced it with the proper stuff and changed the filter again...light still on. Ive been told that it might be a problem with the filter? (Halfords again- desperate measures!) Ive ordered one with BMW but Im not convinced that this is the only issue (although I hope it is!!) Any help greatfully received!) Sarah. |
| First things to check are that filter is correct type and that it is correctly fitted. According to the Haynes manual "MINI One/Cooper up to 07/2004 have a guide sleeve and spring fitted between the element and cover, Cooper S models and vehicles manufactured after that date do not have the guide or spring. Do not remove the guide sleeve and spring from the cover." Also check / replace the oil pressure switch and / or wiring to it. Oil should be 0W-30 Castrol Edge or similar in UK climate. Some other useful info maybe here:- http://www.mini2.com/forum/faults-fi...oil-light.html |
| Tags: oil |
| noises at low revs/rpms | stellablade | First Generation Faults & Fixes | 6 | Oct 26th, 2008 12:07 PM |
| Gearbox noise in low revs | colink24 | Second Generation Faults & Fixes | 8 | Feb 25th, 2008 08:50 PM |
| MCS vs MC response at low revs | luchini | First Generation MINI Cooper S | 8 | Sep 12th, 2007 10:28 AM |
| Ticking noise in low revs | squiders_co_uk | General Discussion | 5 | Jun 27th, 2004 09:20 PM |
| Bogging down at low revs | StrangeConcept | First Generation MINI Cooper S | 26 | May 20th, 2004 01:29 PM |
