| Sounds like a wheel sensor is acting up. The best bet is to get your car in for diagnostic checks, could just be a cable detached or connection acting up which will be inexpensive to get fixed, but drive it carefully until you get it properly diagnosed. We had a Nissan Pathfinder rental car which was almost new and the Stability Control light came on in the middle of Death Valley of all places, the rental company took it back for a dealer check, but we drove it ok albeit carefully until they changed it for a long way without any problem, |
| As Mr Goonery said, its one of the ABS sensors most likely causing the problem. There's one sensor on each corner of the car, and it sends info to the ABS, Traction, and Runflat systems, so throws up all the lights at the same time. Dealer diagnostics tell them which sensor is the cause, its a relatively cheap part, and shouldn't take them long to fix ![]() Sensors can be dirty, or can be a bad connection, but dealers will just replace the part as its relatively inexpensive. |
| Tags: traction control |
| Traction | Mini Demon | General Discussion | 4 | Feb 19th, 2007 01:07 PM |
| Posi traction anyone? | R Betts | First Generation MINI Tuning | 5 | Feb 2nd, 2005 08:59 PM |
| Who needs traction control...... | Charger_Pete | General Discussion | 18 | Oct 29th, 2004 04:19 PM |
| Traction or not??? | GirlyRacer | First Generation MINI Cooper | 34 | Feb 28th, 2004 12:10 PM |
| Traction Control | NutTheBus | First Generation MINI Cooper | 10 | Apr 9th, 2002 07:09 PM |
