Help with fault codes! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 17th, 2008, 06:38 PM
skdotcom's Avatar
MINI Cooper S West Tuning
Local Time: 08:44 PM
United Kingdom Male View skdotcom's Dark Silver & Black 1st Gen MINI Cooper S Profile
Please help!
I have a cherished 2003 MCS with Ray West Tuning mods (supercharger pulley/remap).
I've owned it 2.5 years and its been fantastic, until earlier this week the engine starting misbehaving. Two warning lights on the dash came on (traction and exhaust something or other), and is not running smoothly at all.
I took it to a local garage ( i dont trust the BMW dealer, plus I'm concerned they may wipe my remap from the ECU) who have found the following fault codes
P0108
P0113
P1237
They have been unable to remove the codes, so the lights are still on. Can anyone tell me what sensors need replacing to sort this out?
I love this little car and really want to get it back to normal.
Old Oct 17th, 2008, 07:51 PM
Local Time: 11:44 PM
Kuwait
there is a sticky with all the codes available... search Fault Codes. anyways... look here FAULT-CODES
not sure about the last code though What mods do you have on your MINI?
Old Oct 17th, 2008, 07:56 PM
Kuwait
Found you the P1237 from my Bentley Manual
P1237 : Secondary Upstream Manifold Air Pressure Sensor Low Input.
Old Oct 19th, 2008, 08:43 AM
skdotcom's Avatar
Thanks for the reply. My local garage was able to indentify the codes and descriptions, but was unsure what sensors needed replacing. Specifically, P0108 didn't seem to relate to anything.
Can anyone shed any light on what needs doing to clear all these fault codes, or at least get the car running properly and removing the warning lights from the dashboard!
Old Oct 22nd, 2008, 07:46 PM
skdotcom's Avatar
Ok, got the car fixed today. Fault code P0108 doesnt seem to related to any sensor and cant be cleared but have had new sensors relating to P0113 and P1237, which has sorted the problem. No more warning lights on the dash and it runs perfectly.
Old Jan 8th, 2013, 03:08 PM
Local Time: 03:44 PM
codes
I know this is late...
P0108 manifold absolute pressure/barometric pressure circuit high input
P0113 intake air temperature sensor 1 circuit high
P1237 secondary upstream manifold air pressure sensor low input
Old Jan 8th, 2013, 11:58 PM
Local Time: 09:44 PM
Hi ya
P0108 is your TMAP or MAP sensor
I had a fault with mine and it was the TMAP (it's on your intake manifold between the rad and intercooler) it was a bad connector took it off cleaned the plug job done. My mate had the same problem turned out it was the sensor. It can be tested if you have a code reader or computer
Emission Light/ o2 sensors/Fault codes & Mots roland2003 First Generation Faults & Fixes 49 Mar 10th, 2013 03:34 PM
Self diagnostic fault codes in the Mini odometer digital display? Have First Generation Faults & Fixes 4 Aug 26th, 2012 10:10 AM
Fault Codes DaFlake First Generation Faults & Fixes 9 May 26th, 2012 07:37 AM
Fault Codes iancallaghan87 First Generation Faults & Fixes 3 Sep 23rd, 2007 03:00 PM
Mods causing fault codes?? venox22 General Discussion 3 Oct 31st, 2006 07:43 PM
