Power Steering Pump DIY - Page 3 - MINI Cooper Forum - MINI2 Mini Cooper Forums
LinkBack (6) Thread Tools Rate Thread
  #31 (permalink)
Old May 7th, 2010, 11:55 AM
Local Time: 01:50 PM
thanks guys...i eventually got it removed by having to be a bit brutal with it....i also took it apart and cleaned the electonic bit...the pump is back on the car now and working fantasticlly, just waiting to drive it some more...i have taken lots of pictures and hope to write a full diy for anyone esle who decides to recon thier pump.
let it be known that even though pulsey advised that it is a professenals job, mechanically "minded" ppl could also easily pull this off.
  #32 (permalink)
Old Aug 6th, 2010, 10:25 AM
barleyS's Avatar
Local Time: 12:50 PM
United Kingdom Male View barleyS's Classified Ads
Hi Jon, did you ever write up a full diy?
Im thinking of taking mine off and cleaning it to avoid having to buy another, it has got very noisy!
  #33 (permalink)
Old Aug 16th, 2010, 10:02 PM
Burned out computer module
[quote=pulsey;3750211]
Pulsey, Thanks for the great pics and guide. As you can see from my pics, I was too late. The ingress of commutator dust shows up red on the preamp board. Yours and many other posts have identified the same cause of failure.
The electronics are not adequately isolated from the motor unit. Although the exit holes for the power connections are quite small, they can clearly allow the metallic dust through. The lacquering is pretty ropey, If I prod about with a continuity tester I can easily make connections on the exposed tinned surfaces. Hopefully I can send the whole motor off for a rebuild. That is, unless anyone can supply the module alone. I will use the appropriate thread (not this one) to vent my frustration with BMW service.
It seems obvious that this pathology is an inevitable outcome of the flawed design, and yet customers are having to fork out £900 for a solution.
Sorry I started venting......
ID:	160194   Click image for larger version
ID:	160195   Click image for larger version
Name:	preamp fitted.jpg
ID:	160196   Click image for larger version
Name:	preamp removed.jpg
The Following 2 Users Say Thank You to Shand B For This Useful Post:
  #34 (permalink)
Old Aug 17th, 2010, 11:54 AM
mab01uk's Avatar
Thanks for the pics and write up. No one in their right mind needs to fork out £900 for a main dealer solution............cheaper pumps with warranty are now widely available and any good independent garage can fit it for a couple of hours labour if you don't do diy.
  #35 (permalink)
Old Aug 17th, 2010, 07:22 PM
ratherbewindsurfing's Avatar
Soggied
Wales
[quote=Shand B;3773537]
Thanks and well done !!!
As you say all that is needed now is a source (at the right price) for replacement control modules.
  #36 (permalink)
Old Aug 19th, 2010, 09:25 PM
Quite So: I got a used pump for £70 on eBay. It was sold as working, but nonetheless, I stripped it down for a thorough clean. The computer module was absolutely full of crud but still intact and functional. I didnt get time for photos..... but the lacquer coat was much thicker and better distributed than on my failed unit (photographed earlier)
I seperated the electronics completely, brushed the debris for the PCBs with iso-propyl alchohol. Re-assemnbled then put some araldite in the holes where the 4 power feeds (now soldered to the brush terminals) pass through the shroud.
So far so good, and I sent the original (with the burned out module) to ECU to end up with a re-furbished spare.
  #37 (permalink)
Old Sep 14th, 2010, 03:12 AM
Local Time: 05:50 AM
this is great!!.. i couldve used this info a few hours ago ... I being overly curious decided today to take apart the pump in my wifes car, from the pics its probably good i didnt have the right torx bit and could only get one side off.. when the cover flew off due to the magnetic force(which i had no idea was going to happen because i had no idea what can of worms i was opening) a huge cloud of dust erupted in my face. coughing and blind i ran out of the shop... ha ha.. when the dust settled, i could finally see what the hell mess i caused and wow.. its a magneto thing.. that cant be conducting electricity covered in dust. i dumped out probably 1/2 a cup of this asphixiating purple dust wiped the contacts banged it around to get more dust out, wiped more and put it back together. Bam!! the steering works, for now.. when it goes out again ill give it a proper clean like you have posted.. thanks for the info.. if you can tell me how to get this horrible taste out of my mouth form the dust let me know,,
Rob
  #38 (permalink)
Old Sep 27th, 2010, 05:54 AM
South Africa
Hi Guys,
This guide helped me a lot. So thank you!
I stripped my pump out yesterday. Cleaned everything I possible could and bleed the system. It's working now! I was having intermittent problems. Pump
would only work after letting the car sit for a few days. Would only work for about 30 min as well. Since last night no problems.
I want to know about the fan that cools the pump. Does it run off a temperature control or is run constantly and does it run at 12 volts?? Mine wasn't running at all last night so I'm a bit concerned about it. Does anyone know?
  #39 (permalink)
Old Sep 27th, 2010, 07:42 AM
mab01uk's Avatar
Quote: Originally Posted by ryan_cpt (original)
Hi Guys,
It should not run constantly, this link may help:
MINI COOPER :: North American Motoring - Power Steering cooling fan issue
You should also check the fuse:
MINI COOPER :: North American Motoring - Power Steering Fan question
  #40 (permalink)
Old Apr 23rd, 2012, 04:46 PM
DIY
hi,
I cant open the motor house,
How did you manage to open the motor house and see the module?
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-faults-fixes/163712-power-steering-pump-diy.html
Posted By For Type Date
Mini Cooper Miscellaneous Information  - SooperCooperInfo.com This thread Refback Jan 27th, 2009 10:24 PM
Powertrain This thread Refback Dec 6th, 2008 09:09 AM
Electrical This thread Refback Dec 3rd, 2008 12:47 AM
Troubleshooting or Repair This thread Refback Nov 22nd, 2008 07:18 PM
DIY This thread Refback Nov 20th, 2008 01:37 PM
After Market Parts This thread Refback Nov 17th, 2008 09:55 PM
Power steering Pump replaced-Steering slightly off centre Rooster First Generation Faults & Fixes 4 Apr 26th, 2010 01:35 PM
Power steering pump GDC First Generation Faults & Fixes 0 Aug 16th, 2005 10:06 PM
Power steering Pump indigorallye First Generation Faults & Fixes 15 Jan 23rd, 2004 12:06 PM
Power Steering Pump virafp Maintenance & MINI Care 3 Sep 15th, 2003 12:31 PM
