Door closed switch - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 5th, 2008, 06:05 AM
Local Time: 10:18 PM
Scotland
Door closed switch
Been having a problem with the interior light coming on and the passenger window going down a wee bit.
Was thinking its a problem with the sensor on the door.
any advice would be great thanks.
51 plate mini cooper.
Old Nov 6th, 2008, 05:50 PM
Scotland
been having a look for the switch that tells if the door is shut, but cant see it.
Anyone know where it is on the door?
thanks
Old Nov 6th, 2008, 06:23 PM
N.O.T.R.A.M.O.O
Local Time: 11:18 PM
Scotland Male
The switch you are talking about is built in to the door catch assembly itself, to gain access you will have to remove the door card.
It is possibly that switch, but it is also a possibility that it is te BC1 unit with water ingress...
"Allow me to explain... Understeer is when you hit the armco going forwards, Oversteer is when you hit it going backwards!"
Old Nov 7th, 2008, 06:14 AM
Scotland
BC1 unit sounds expensive.
I
Door lock Micro-switch Poggy First Generation Faults & Fixes 0 Mar 8th, 2005 12:54 PM
Where is the door Switch? brett First Generation Faults & Fixes 2 May 18th, 2004 08:37 AM
Does Anyones Door Stick Out? (when closed) Dec General Discussion 2 May 10th, 2003 12:31 AM
about toggle switch garage door opener... minigal First Generation MINI Exterior 20 Apr 7th, 2003 02:34 AM
