HELP!! annoying misty window's :-( - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Dec 2nd, 2008, 05:26 PM
Sir Jake the Brit's Avatar
Local Time: 10:21 PM
every time i get in my S when its rather cold or damp or like most offten both!!!
all the window's steam up.
or when i 1st put the aircon on.............. they steam up!!!
anyone else have this same problem???
has anyone got over it???
many thanks
Jake
Old Dec 2nd, 2008, 05:40 PM
Paul's Avatar
MINI2 No.1
Local Time: 11:21 PM
England Male
Generally I've found that you're best to either keep the aircon on, or keep it off. Switching between the two results in lots of condensation/moisture.
Old Dec 2nd, 2008, 05:43 PM
http://www.mini2.com/forum/2nd-gen-i...g-windows.html
Old Dec 2nd, 2008, 06:35 PM
Morri7's Avatar
Scotland Male View Morri7's Indi Blue & White 1st Gen MINI Cooper S Profile
Check the air recirculation is not on. Even if the light is not on give it a press just in case. I had a problem with this and thought that the heater had packed up on my car as it was always steaming up. The problem was solved when I pressed that button. It was like this had got stuck on.
Old Dec 2nd, 2008, 06:47 PM
Gristy's Avatar
Always on Overboost
England Male View Gristy's Chili Red & White 2nd Gen MINI Cooper S Profile View Gristy's Classified Ads
I use Rain X - anti mist on the inside of the windows - works a treat
Can tell it does the job as i don't do the bit in the corner as the sat nav doesn't stick else - this bit steams up and the rest stays clear all the time
Old Dec 2nd, 2008, 08:20 PM
United Kingdom Female View I love MINI, Laura's Royal Grey & Silver 1st Gen MINI Cooper S Profile View I love MINI, Laura's Classified Ads
I also use Fog-X and it works wonders. My old MINI One was worst for it and always seriously misting up especially when it was raining and cold. My first day of ownership I almost couldn't see out on the motorway and at night - not good! I even took it back for this problem. They told me to put the air con on. I didn't have air con! Fog X cleared it up immediately. Its brilliant and even use it on the rear view mirror as this used to even fogged up. Just a MINI trait I guess! Not to bad with our current S but do it anyway cos its a good excuse to clean the windows!
Misty Windows... Serious.... Whats Wrong? ScottyBoy First Generation Faults & Fixes 4 Jun 8th, 2008 09:44 AM
Misty Driving Lamps sv650 First Generation MINI Exterior 3 Oct 31st, 2005 08:11 PM
Misty Spots JG.26 First Generation MINI Exterior 6 Feb 1st, 2004 08:03 PM
