| You'll probably find it's the water in the tank/pipes that's frozen, not a fault with the jets. They may be heated, but not to a temperature high enough to melt frozen water backed up in the pipes that feed them. |
| From what I've been told they just heat the water as it exits the jets. It does not guarantee that the rest of the system is liquid. I've got them & I'm not sure how useful they are! |
| As per Scrogg & Gristy. It's only the jets that are heated not the feeder pipe so I would suggest that this is frozen. To stop this freezing you need a strong water/screenwash mix. Mine froze last week, but a good glug of screenwash in the system means they haven't frozen again since thawing |
| mine do this even with heated washers and strong mix liquid that is supposed to be good to -10 or more! Its normal, takes me around 10 miles of driving before they warm enough of the pipes to spray in a useful way! The other day on the way home they worked fine standing still and car was not frozen up, then drove off 15 miles down the road and i spray to find they have frozen! so had to switch the defrost button on to warm them again |
| Heated washer jets | saz007 | General Discussion | 31 | Feb 15th, 2007 03:26 PM |
| Heated washer jets | Tonyt3 | General Discussion | 21 | Mar 4th, 2005 11:13 AM |
| Heated Washer Jets. | Thomo | First Generation MINI Exterior | 5 | Jan 22nd, 2003 09:18 AM |
| Heated Washer Jets | PERCY | First Generation Faults & Fixes | 17 | Jan 13th, 2003 08:02 PM |
| Heated Washer Jets | Markizok | First Generation MINI Exterior | 5 | Jan 1st, 2003 10:27 PM |
