Ticking noise on 1st, 2nd gear or neutral - MINI Cooper Forum - MINI2 Mini Cooper Forums
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old Dec 12th, 2008, 10:05 AM
Local Time: 08:51 PM
Singapore
Hi All
I'm experiencing a ticking noise that appears to be coming from the front right wheel on 1st, 2nd gear or neutral when I'm driving on a very smooth surface(eg. a cemented car park). This occurred after a tyre shop removed my wheels by knocking them out with a wooden block as they locked onto the centre ring adapter.
Has anyone experienced this before? I hope it is not a problem with the drive shaft.
Your comments and feedback is much appreciated.
Old Dec 12th, 2008, 08:06 PM
JustACooperClubman's Avatar
Clubbing in Miami
Local Time: 12:51 PM
United States Male View JustACooperClubman's Hot Chocolate & Silver 2nd Gen MINI Cooper S Clubman Profile
When was the last time the dual mass and clutch kit were replaced?
'08 Clubman Cooper S - Hot Chocolate/Silver "Mousse" (Due 2/16)
'05 R53 Cooper S - Chili Red/White "RB"
Old Dec 13th, 2008, 12:45 AM
Singapore
I've only done 15,000km. Have not replaced any wear and tear parts, save for the belt tensioner at 10,000km.
Old Dec 13th, 2008, 02:08 AM
lukebob's Avatar
Most Wanted Mini
Local Time: 01:51 PM
United Kingdom Male View lukebob's Classified Ads
Quote: Originally Posted by vokey_sg (original)
Hi All
ye i had this with my mini 1st and 2nd ... i thought it was a wheel bearing or sumthink to do with the wheel on the right side ..
turns out the sound was from under the car and in sum places it can be made to echo so it sounds like its from either side ..
spoke to bmw bout it the took a look see and i had a hole in my flywheel ...
just double check where u think u can hear it from
hope you get it sorted
Not Even A Surgeon Could Remove This Smile
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-faults-fixes/165621-ticking-noise-1st-2nd-gear-neutral.html
Posted By For Type Date
FAULTS AND FIXES on MINI2 - Fuel For Your MINI Obsession - MINI Cooper - S - One - Diesel - Works - Cabrio | BoardReader This thread Refback Dec 17th, 2008 04:21 AM
2007 MINI COOPER R56 sticky gear change 1st to 2nd gear hankdu Second Generation MINI Cooper 1 Aug 31st, 2008 08:17 PM
1st Gear to 2nd? Jonny H First Generation Faults & Fixes 5 Nov 9th, 2006 01:50 PM
hard to get 1st and 2nd gear Richy777 First Generation MINI Tuning 1 Mar 26th, 2006 06:06 AM
Jerky gear change 1st -> 2nd purchox First Generation Faults & Fixes 6 Jul 27th, 2005 11:13 AM
exhaust crackle & clunk noise between 1st and 2nd gear Gr1zzLy First Generation MINI Tuning 3 Jul 4th, 2005 09:19 AM
