Heater blowing hot + cold / losing coolant - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 7th, 2009, 07:43 PM
Local Time: 03:44 PM
Hi,
I have a 2005 Mini Cooper with air-con.
The fan seems to blow intermittent hot and cold. Randomly, the heater will blow cold air even though temp set to hot.
The car has been drinking coolant for the last month or so. Prob at a guess, maximum down to minimum level every 2 weeks. Thought this might be an airlock but so far it's still drinking the stuff.
Any ideas on what is wrong with the car?
Old Jan 7th, 2009, 09:00 PM
Local Time: 04:44 PM
United Kingdom Male View 1958 harry's British Racing Green & Body Color 1st Gen MINI Cooper S Profile
Ours was losing coolant (altho the heater was working fine) turned out it was the thermostat housing, all fixed under the cherished warranty
Ours is a 55 plate MCS with Climate control.
Old Mar 4th, 2011, 07:53 PM
Nataliewinter's Avatar
United Kingdom View Nataliewinter's Classified Ads
I had the same problem, air con randomly blowing hot then cold, despite the temp setting on the climate control! Also had an engine light come up on my dash that said the engine was overheating, even when started from cold.... Turned out I had a hole in the radiator so coolant was leaking! all sorted now! Phew!
2008 cooper with climate control
Mini Blowing cold air pcjr First Generation Faults & Fixes 2 Nov 17th, 2011 03:47 PM
Exhaust Sound (Cold vs. Hot) batou First Generation MINI Tuning 16 Jun 13th, 2008 01:31 PM
Air Con Blowing Cold After Regas scleaton First Generation Faults & Fixes 1 Jun 11th, 2007 02:20 PM
AC blowing hot and cold Cally95 First Generation Interior & Ice 9 Jul 19th, 2006 05:20 AM
