| Coolant Level Low Hi, Just doing general checks under the bonnet and found my coolant level is low, Do I require special coolant or can I top it up with a water antifreeze mix?? Is there any know leaks or issues with the coolant system, should I be worried or is this normal??? Many thanks Dan |
| Other common areas are: - split coolant header tank - split seams or hole in radiator. - drop due to air in system (you would hear gurgling in the footwell if this was the problem). |
| Cheers guys, have got some and have topped it up, will moniter over the next few 100 miles. It could of just settled, there has been no patched on the driveway but the car is fairly new to me still and still 'cherished' so would rather a fault now in a odd kinda way. Oh and sorry its been moved... still learning |
| It's on the transmission side of the cylinder head, just under the radiator cap. If you remove the air intake and the battery box, you'll get access to it. Here's a picture - it's #10. RealOEM.COM * BMW R50 Cooper WATERPUMP - THERMOSTAT Mine has a slow leak (a couple ounces a week). Ordered some parts, and will get it fixed soon, hopefully before it gets worse. ![]() |
| coolant level going down | jksgoh | First Generation Faults & Fixes | 4 | Apr 13th, 2007 12:47 PM |
| Coolant level ? | fraujmj | First Generation Faults & Fixes | 3 | Jan 27th, 2006 05:51 PM |
| coolant level - please help | matt21 | First Generation Faults & Fixes | 3 | Oct 22nd, 2004 04:25 PM |
| Coolant level right on min level | rainbowdreamer | First Generation Faults & Fixes | 2 | Aug 24th, 2003 04:06 PM |
| Coolant level. | KenL | First Generation Faults & Fixes | 9 | Nov 29th, 2002 06:02 AM |
