airbag warning light still on after reset tool - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 26th, 2009, 03:06 PM
Local Time: 12:52 PM
United Kingdom View bigpoppa81's Classified Ads
I bought a reset tool for my mini r53 and its still not taking the airbag light off?
i pluged it into the odb2 socket in the footwell, it came up with connection error. The tool has various other makes on the unit it works for so when i go onto the bmw e46 odb2 setting and try the airbag reset option on that one it says reset ok but its not gone off, i can reset the service settings on the bmw options but not my mini airbag light under the mini setting.
ive been in touch with the garage i got it from last week and they said they will get a specialist electrician who works on bmws/ porsches etc and he will sort it out.
What he has that the other auto electrician ive took it too does have god knows.
Im guted this hasnt worked.
Old Jan 26th, 2009, 03:07 PM
KillerByte's Avatar
Where does that road go?
Send a message via MSN to KillerByte
Local Time: 01:52 PM
England Male View KillerByte's Hyper Blue & White 1st Gen MINI Cooper S Profile
Perhaps there is a more serious problem you should get looked at?
Old Jan 26th, 2009, 03:15 PM
i just dont understand whats wrong with it, ive checked the wires under the seats and they are fine, its been run on a auto electricians diagnostics machine and its still not going off, ive noticed when you turn the car on and the lights on the dash go off it goes off for a second then come back on?
Old Jan 26th, 2009, 03:19 PM
minicabrio's Avatar
Soon to be deleted !!
United Kingdom Male View minicabrio's Space Blue & Silver 1st Gen MINI Cooper S Profile
Your reset tool will only reset the light... if there genuinely is a fault with your airbag system, the fault code will reappear, and so will the light.
Resetting the fault code does not solve the initial problem!
Old Jan 27th, 2009, 08:03 PM
aussie11's Avatar
United Kingdom Male View aussie11's Classified Ads
Have you moved the wires about under the seat sometimes my light wont reset unless I move the wires a little
Airbag reset tool joen14 Maintenance & MINI Care 11 Aug 5th, 2008 08:12 PM
BMW Airbag Reset Tool joen14 General Discussion 3 Mar 22nd, 2008 09:29 PM
airbag reset tool erb777 General Discussion 1 Jan 29th, 2008 06:03 AM
airbag reset tool, need to borrow one if poss erb777 First Generation Faults & Fixes 0 Jan 26th, 2008 06:09 PM
who has used a b200 srs airbag reset tool parklaneuk General Discussion 3 Nov 28th, 2007 10:10 PM
