Radiator cooling fan jammed on ? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 28th, 2009, 06:42 AM
Local Time: 08:52 PM
Australia
Australia Radiator cooling fan jammed on ?
Hi
The radiator cooling fan on our BMW Mini Cooper is stuck on all the time , even when the engine is turned off . Has anyone had this problem and if so what was the cause ?
Rgds Les Jones
Old Jan 30th, 2009, 07:37 AM
Local Time: 12:52 PM
United Kingdom View Alex_miniS's Classified Ads
hi mate
It will usually be down to the thermostat on the back of the radiator. That controls when the fan cuts in and out. The fan can run on even when the car is off, but mine ended up turning off when it drained my battery!
Think the thermostat with the housing is about 30quid!
Old Jun 11th, 2009, 01:12 AM
Local Time: 06:52 AM
Les,
Did you determine the problem with your fan? I am having the same issue.
Cheers!
DS/B MCS Stripes, Black Leather, Sport, Premium, Navigation
Cooling Fan Howie Maintenance & MINI Care 0 Oct 14th, 2007 07:47 AM
Cooling Fan minidonut First Generation Faults & Fixes 3 Apr 3rd, 2007 05:03 PM
radiator cooling fan problem??? eddieboyII First Generation Faults & Fixes 3 Jul 1st, 2004 09:42 PM
Cooling Fan... foxtrotxray First Generation Faults & Fixes 4 May 26th, 2004 03:53 AM
Bleeding the radiator (air in cooling sytem) jmardy Maintenance & MINI Care 2 Jul 12th, 2002 12:26 PM
