| overheating mc .. my brg mini cooper over heated yesturday on the way to work....noticed the tank was empty so i filled with water and bled the valve for air..called the aa out just to check it all over and he said i have a leaky radiator..it must be just dripping tho because i can get from manchester to stockport and back 40miles away ...and there is still some water in the tank just wondering if its worth getting a new radiator or just putting some radweld in for now till i get the money for the new rad...just wondering tho where do i put the radweld? ive been told i cant put it in the filler tank as it wont work properly...(by an AA man) .if i did get a new radiator is there any aftermarket ones floating about for a mini cooper? cheers chris |
| I used radweld today..as you explained using that fiiler cap near the battery box...soon as i put it in tho ,it changed the colour of the water in the expansion tank aswell..Is that right ? il find out tomorrow if its worked or not..so il leave another post then.. |
| Think it has fixed it..but now once every month the filler tank lid pop off and the coolant will over flow for some reason (think its an airblock) other than that its been fine..how hot should the radiator be to the touch? cheers |
| Overheating | 20thebear | First Generation MINI Tuning | 11 | Feb 17th, 2009 06:25 PM |
| Overheating | groovecoop | First Generation Faults & Fixes | 2 | Nov 16th, 2007 03:04 PM |
| Overheating? | Tara&Paul | Second Generation Works | 29 | Nov 4th, 2007 07:31 PM |
| Overheating | kgouin | Second Generation Faults & Fixes | 6 | Sep 19th, 2007 03:51 AM |
| not really overheating, but | joplus | First Generation Faults & Fixes | 1 | May 20th, 2007 12:31 AM |
