Whining/rattly noise - possible gearbox? - MINI Cooper Forum - MINI2 Mini Cooper Forums
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old Mar 15th, 2009, 04:08 PM
Local Time: 01:52 PM
Denmark
Hello,
I have discovered a strange noise in my 2001, 50000 miles Cooper. It is only there when the engine (and probably gearbox) is cold and audible primarily in 2nd gear and sometimes in 3rd gear as well. It sounds quie "rattly" like a box of screws being shaken or something like that. The strange thing is, that it sounds as if it comes from under the driver (left) side footwell.
The gearbox shifts fine, as far as I know, though a little tight, but I suppose that it is meant to be that way..
So - what do you think? Where does the gearbox sit? And would a 2005 gearbox with this code: GS5-52BG-TBHA fit?
Thank you very much for your help..
Old Mar 15th, 2009, 04:47 PM
Denmark
Maybe I should add: The noise comes both "off and on boost" and is there from 3-4,000 RPM. If I press down the clutch and then "slip" it fast, the sound comes on as well just as the clutch engages, so to speak. My hope is that it is a vibration from something else under the footwell, but....
Old Mar 18th, 2009, 06:25 AM
Denmark
Anyone?
Old Mar 27th, 2009, 04:43 PM
Denmark
Hello?
I have discovered that the noise is most apparent "off boost" ie. when decelerating. 2nd & 3rd gear - and in all temperatures it appears. Any suggestions?
Old Apr 16th, 2009, 03:04 PM
Local Time: 10:52 PM
Australia
I have exactly the same problem. But mine is more prominent around 2K-3K RPM.
Old Apr 19th, 2009, 08:18 AM
Menace Motorsport
Australia
It could be the throw out bearing and bearing guide rattling, there is a modified bearing and guide/sleve you can get from your local BMW/mini dealer,
could also be a box but, best to get a oil sample from it to check for metal filings.
Tom
Tags: ,
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-faults-fixes/169545-whining-rattly-noise-possible-gearbox.html
Posted By For Type Date
FAULTS AND FIXES on MINI2 - Fuel For Your MINI Obsession - MINI Cooper - S - One - Diesel - Works - Cabrio | BoardReader This thread Refback Mar 31st, 2009 05:08 PM
Whining Gearbox SHERIFFFATMAN First Generation Faults & Fixes 3 Feb 16th, 2009 01:34 PM
Whining squeaking noise Barbados Mini2k2 First Generation Faults & Fixes 3 Feb 5th, 2009 10:23 PM
whining noise when driving BlackEyedPea First Generation Faults & Fixes 8 Nov 27th, 2008 09:14 AM
whining noise muisje S First Generation MINI Cooper S 9 Oct 23rd, 2005 09:32 PM
Anyone had a rattly gearbox? Technospirit First Generation MINI Cooper S 18 Jan 5th, 2004 04:09 PM
