reverse gear - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 16th, 2002, 12:29 PM
bo nydal's Avatar
Local Time: 12:52 PM
Angry reverse gear
im sometimes having problems engaging reverse gear on my 9 mth old 6000 mile cooper. it either goes in first time or plays up like bloody hell. ive tried putting it other gears first and reving the engine ect. none of which make any diference. we borrowed a mini one from our dealer which was worse than our car is it a common problem?.
Old Oct 16th, 2002, 12:33 PM
Martin L's Avatar
MINI defector
Local Time: 01:52 PM
England Male View Martin L's Astro Black & Body Color 2nd Gen MINI Cooper Profile
Have you had the gear linkage fix yet?????
As reverse doesn't have sychromesh it is harder to put in gear but shouldn't be as bad as you are experiencing
MINI, RX8 and MX5 - Done those............. It's now TTime
Unofficial MINI2.com bean counter
Old Oct 16th, 2002, 01:10 PM
HarryHBMCC's Avatar
Local Time: 07:52 AM
Canada Male View HarryHBMCC's Laser Blue & Black 2nd Gen MINI Cooper S Convertible Profile
Arrow
My MINI of similar age, almost 6 months and over 9000kms also has trouble getting into reverse sometimes. The first thing I do which seems to help is to snap it into reverse -- going slowly seems to get caught up. If I can feel that it didn't go all the way in, I put the stick into neutral, drop the clutch out, rev the engine a bit, put the clutch back in and it goes into reverse fine after that.
A previous car had a similar problem which was solved by putting it into first and rolling forward a bit but this doesn't seem to work as well in the MINI. The neutral rev seems to do it.
For the record, my car has had the gearbox linkage fix. It was acting up before the fix, felt fine right after it but then started acting up a few weeks later. It is usually fine but once in a while it gets caught there. Lack of synchros and the 5th->reverse lockout probably.
Harry
Old Oct 16th, 2002, 03:01 PM
R1's Avatar
R1
Addicted to Speed!!
United Kingdom Male View R1's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
Just seen this thread.
I have reported something like this on here:
http://www.mini2.com/forum/showthrea...threadid=17033
Reverse Gear MiniFr34k General Discussion 4 Jun 3rd, 2005 02:23 PM
Reverse Gear leightongray First Generation MINI Cooper 31 Dec 30th, 2004 09:55 PM
crunching in reverse gear dee First Generation Faults & Fixes 14 Nov 10th, 2004 06:41 PM
Reverse Gear MINI ADI First Generation MINI One D 11 Sep 5th, 2003 09:20 AM
reverse gear den123 First Generation Faults & Fixes 4 Aug 13th, 2003 11:42 AM
