Squeaking/twittering noise from cold startup at idle. - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 31st, 2009, 11:34 AM
Local Time: 01:52 PM
Male View jasonblake7's Classified Ads
Hi Guys.
Ive recently noticed upon starting up from cold when the car is left over night at idle that there is an audible "twittering/squeaking" noise coming from what I think is the Alternator/fan belt area I think its also known as the PolyV belt. About 5 miles down the road the noise stops. I had the fanbelt replaced at a bmw/mini dealer in November of last year.
Anyone have any ideas of the cause or any tests to try to diagnose the issue further.
Does the belt need retensioning ? or is it some sort of bearing issue ??
the car is a r50 53 plate mini cooper petrol.
thanks for any responses. I can do a recording of the noise if that would be any help with my mobile and put it on youtube.
Old Mar 31st, 2009, 11:44 AM
Keano's Avatar
JCW 250
United Kingdom Male View Keano's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Keano's Classified Ads
Not sure about your noise but this photo shows the tension in your belt - in the photo is how it should look - if the metal prong with a twisted end has recessed into the spring then the belt has stretched/tension is low...
Your belt shouldnt have stretched already if you only got it changed at the end of last year...
Sorry cant really help you...
Running 211whp
Old Mar 31st, 2009, 12:01 PM
Hi Keano.
Thanks for the picture of the spring. Where can I view this spring from ? does the car need to be on a ramp ?
Old Mar 31st, 2009, 12:10 PM
Keano's Avatar
JCW 250
No its very easy no ramp needed, just look down the drivers side of your engine where the supercharger is and you will see the spring...
Running 211whp
Old Mar 31st, 2009, 12:53 PM
Ive just started the car, the noise is there. IF you apply some revs the noise disappears. As soon as the car goes back to normal idle rpm the noise comes back. IS this a tension issue ? Also Keano its only a Cooper so does not have a supercharger so I think your picture shows the tensioner spring for the supercharger belt ??
Old Mar 31st, 2009, 01:04 PM
Keano's Avatar
JCW 250
My appologies - I read your original post too quick and didnt spot that!! Sorry dude. I had a similar noise on my S which went after changing the belt so incorrectly applied it to your car... my bad
Running 211whp
Old Mar 31st, 2009, 07:24 PM
Local Time: 12:52 PM
You may have a dry or worn bearing on one of the tensioner pulleys
Old Mar 31st, 2009, 08:06 PM
c.gray2008's Avatar
United Kingdom View c.gray2008's Indi Blue & Body Color 1st Gen MINI One Profile View c.gray2008's Classified Ads
i have this problem quite often especially after rain.
try starting the car and dropping some talken power on it, in my case the noice instantly stops.
and its much cheaper than taking it to a garage
Old Apr 1st, 2009, 06:06 PM
5meodmt's Avatar
MINI inspiration
United Kingdom Male View 5meodmt's Chili Red & Black 1st Gen MINI Cooper Profile
yeh mine too been doing it for year and a half, ever since i bought it second hand 53 plate cooper, dissapears pretty quickly by driving or the stereo masking it
35500 on the clock so im a long way off inspection2 where the aux belt gets changed?, im ignoring it.
Old Apr 14th, 2009, 09:55 AM
Vines BMW in Crawley looked at my mini sat as they were the ones who replaced the belt originally. When i came to pick the car up was told that they have taken the belt off and done some tests and the noise is coming from the alternator. They quoted me around £500 to change it.
I said to the guy, I cant see it being the alternator myself as why if you spray some WD40 onto the belt and alternator pulley as its going round does it stop straight away. the response "was maybe the oil is getting into the bearings inside the alternator and is lubricating them".... Yeah right
On sunday me and a friend managed to get some talcon powder onto the inside of the belt via a syringe and some rubber tubing, hey presto this morning when starting from cold no noise...
IS it the alternator now...... I think not.
Old Apr 16th, 2009, 11:11 PM
MINI-Morgan's Avatar
MINI Obsessed...
Maybe what they mean is the alternator is dry and causing increased drag which is causing the squeek when first turning over??
Old Apr 21st, 2009, 04:15 PM
United Kingdom Male View Patchoulian's Classified Ads
Quote: Originally Posted by jasonblake7 (original)
Hi Guys.
FWIW my 2004 MCS/33000mls does this, and has done for the past 6 months. Service not due until October - I'll wait until then. I've just read an article in Practical Mechanics that says this is a symptom of a worn 'serpentine belt', although I do have a niggling concern that it could be the water pump bearing.
Rob
Old Aug 11th, 2009, 10:12 AM
I have had the belt replaced by a local garage to where I work 2 weeks ago. No noise since so definately was the belt.
So BMW three bridges saying its definately the alternator and wanting 500 to change it was completely wrong. Im going to try and get the money back on the belt out of principal now.
Squeaking sound coming from engine when car is idle DioNYc Second Generation Faults & Fixes 1 Jul 2nd, 2008 09:47 AM
startup noise and induction demetri First Generation MINI Tuning 0 Mar 13th, 2008 11:35 AM
Engine noise on startup KAS_MINI First Generation Faults & Fixes 16 Jan 22nd, 2007 11:11 AM
FYI Rusting Pulley causing squeaking at cold start warped First Generation Faults & Fixes 6 Oct 17th, 2006 02:29 PM
Surging Idle After Startup! Zoomby_U First Generation Faults & Fixes 0 Jun 26th, 2003 01:54 PM
