Midland R65 Gearbox Oil (MTF 94) - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 8th, 2009, 06:54 PM
mab01uk's Avatar
Local Time: 12:31 PM
Decided to change the oil in my Midland R65 Gearbox (2002 Mini One) to prolong its life but even my local BMW MINI parts dealership did not stock the special MTF 94 Manual Transmission Fluid recommended! (nor did Halfords or any other local car spares retailers).
I eventually found it stocked in the Land Rover Dealer Parts Dept next door to the MINI dealer in Thames Ditton for £7.50 per litre bottle (2 Litres required) LR Part No. STC 9158. It is used in several Land Rover, Rover and Honda gearboxes.
At 45,000 miles there are no noises yet but found lots of metal particles in the old oil and on the magnetic drain/filler plugs.
Advise everone with a good Midland box to change yours NOW, I wish I had done this earlier - a cheap and fairly easy job to do .............don't rely on "filled for life" with this gearbox out of BMW warranty.
The gear change is much smoother now too.
Old Apr 8th, 2009, 11:42 PM
NeuroBeaker's Avatar
PowerSteeringPumpActivist
Local Time: 11:31 AM
Scotland Male View NeuroBeaker's Indi Blue & Body Color 1st Gen MINI One Profile
Roland at GTT changed the gearbox oil on my second midland gearbox - I noted the same: smoother gear changes.
Having said that, I've now started to notice it's roughening up a bit again... I wonder if that's it needing another change or whether the gearbox is turning itself into cheese again.
NeuroBeaker - Proud owner of Zeus (a 'modestly modified' 2004 MINI ONE).
Helpful Links: [1st Gen. Power Steering Pump (PSP) Failure Guide] [1st Gen. PSP Repair] [Thread Titles] [Adverts Fix]
Old Apr 9th, 2009, 07:27 AM
mab01uk's Avatar
For the small extra service cost I think I would now change Midland gearbox oil/fluid at each normal engine oil service or at least every other one just to keep an eye on things..........the oil drained out can tell you alot and it allows cleaning off the magnets to catch any more harmfull metal debris before it circulates damaging the bearings and syncros.
Old Apr 10th, 2009, 07:38 PM
United Kingdom Male View Silverado's Pure Silver & Body Color 1st Gen MINI One Profile
The Haynes manual says " Refilling the transmission is an extremely awkard operation".
What exactly is involved ? What did you use to refill it ?
Old Apr 11th, 2009, 09:27 AM
mab01uk's Avatar
I followed these instructions on some US MINI forums below and refilled using a plastic tube and a funnel but job would be done a lot easier using a proper garage lift/ramps:-
MINI COOPER :: North American Motoring - Transmission Fluid Change How To?
Manual Transmission Fluid Change How-To - Lone Star Mini Club Forums
(Also the pics shown of the metal debris on the drain plugs was very similar to what I found on mine! )
Although the manual transmission fluid for the MINI is called a “lifetime” fluid it’s far better to change it at not longer than 50,000 mile intervals (would advise more often on the Midland Cooper/One gearbox). It’s not so much that there will be a viscosity break down, but that it will be saturated with wear metals. There is no filtration system in the manual transmission only magnetic fill/drain plugs or disc to capture the large debris.
Tools needed:
8mm allen wrench or socket
Breaker bar
Torque wrench
Equipment:
Funnel
Tubing
Fluid receptacle
Ramps
"Operate the vehicle to warm the transmission and suspend any particulates, raise the front of the vehicle either by driving onto ramps or lifting and placing on stands. I backed the MINI up an incline before driving up ramps in an attempt at leveling the vehicle as much as possible.
Loosen the upper fill plug on the transmission case, then loosen the lower; I recommend a breaker bar and allen socket because often the plugs are over tightened from the factory. Once loose the plugs unscrew easily by hand; then drain the old fluid into a wide mouth receptacle.
Screw in the lower fill plug and hand tighten. Attach a tube to a funnel and feed through the top of the engine compartment near the exhaust manifold into the fill plug opening. A 3/8ths ID/1/2 inch OD tube is just about right; the length of the tube will be determined by the type of funnel used.
Add 1.75 quarts (or until fluid flows out of the fill plug) of your favorite transmission fluid. Screw in the top fill plug and torque both top and bottom plugs to 32ft-lb for the MCS, 22 ft-lb for the fill and 30 ft-lb for the drain plugs on the Cooper/One.
I had the stock MTF-94 transmission fluid analyzed after a 14,000 mile change interval and the results were outstanding; the stock fluid is a quality product so there’s no need to loose confidence in it. Many prefer Red Line MTL and that’s ok too."
The Following 3 Users Say Thank You to mab01uk For This Useful Post:
Old Apr 15th, 2009, 03:21 PM
Cinimod's Avatar
Send a message via MSN to Cinimod
England
Hmmm... wish I had known this... I am 500 miles over 90k on a 51 reg (2002) mini cooper and driving down the road today it went click, click, thunk, jolt, bang and left a load of goo all over the road and well not work in gear.
Now I am in need of finding somewhere good to take a look at it and see if I need a new gearbox, the local mini garage on a quick call said, oh, allow over 3k for it!
On a post on the mini forums, they say you should replace it with a Getrag gear box, a 6 speed if you have the money! - can anyone recommend anyone to do the job near Slough?
Old Jun 18th, 2009, 07:31 PM
ScottyBoy's Avatar
Obsessive Car Cleaner OCC
The later model coopers came with a 5 speed getrag box it may be worth finding one of these.
Old Jun 18th, 2009, 08:03 PM
mella yella fella's Avatar
England Male
I've just had my 5 speed getrag box replaced cos it sounded worse than a series one Land Rover! only done 40,000 miles!!
so if you see one on ebay, and its from norfolk, dont touch it
Clubbin' it and Lovin' it
Old Jun 19th, 2009, 07:48 AM
Cinimod's Avatar
England
Can I ask how much it cost to get it done... I went on breakeryard.com and got an offer from someone to do it for about £900 - not sure how good they are though!
Old Jun 19th, 2009, 10:09 AM
tnoy66's Avatar
POP..POPPOP..POP
England Male View tnoy66's Pepper White & Black 1st Gen MINI Cooper S Profile View tnoy66's Classified Ads
Cinimod give these guys a call and see if they can help, they can collect from anywhere in UK
Cleckheaton Gearbox and Clutch Centre
Old Jul 14th, 2009, 10:24 AM
Cinimod's Avatar
England
Thanks TNOY66 - they picked up the Mini yesterday, so hopefully it will get a new lease of life!
Old Jul 15th, 2009, 07:38 AM
Cinimod's Avatar
England
hmmmm.... no ansa on the phone when I tried a couple of times yesterday, and no ansa at 8:35 this morning - will I see my mini again?
Old Jul 15th, 2009, 09:46 AM
tnoy66's Avatar
POP..POPPOP..POP
Hope you see it again and hope it's fit and healthy too
Old Jul 15th, 2009, 10:03 AM
Cinimod's Avatar
England
Yup - forgot to update... 8:45 got through - they had 2 men down yesterday and were manic - she should be up on the ramp today and hope to hear the verdict later...
  #15 (permalink)
Old Jul 29th, 2009, 07:54 AM
Cinimod's Avatar
England
She is back and running fine! - thank you ....
Tags: , , ,
How much oil does the Midland gearbox take? 3GGG Maintenance & MINI Care 3 May 21st, 2008 04:16 PM
Midland Gearbox: Ticking maggie444 First Generation Faults & Fixes 2 Jun 18th, 2007 02:19 PM
Midland Transmission Oil Bajanmini First Generation MINI Tuning 0 Feb 22nd, 2007 11:40 AM
R65 Gearbox problem assara First Generation Faults & Fixes 1 May 3rd, 2006 08:28 AM
Did the Midland gearbox get a fix? Torkor First Generation Faults & Fixes 0 Sep 23rd, 2005 09:00 AM
