Vibration in steering wheel - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 9th, 2009, 04:46 PM
theone's Avatar
Local Time: 01:52 PM
Scotland Male View theone's Dark Silver & Black 1st Gen MINI Cooper S Profile View theone's Classified Ads
Hi,
My 2004 MCS has done 50,000 miles and just had the drivers side lower arm bushes replaced (apparently the passengers side bushes were still fine)
I was hoping this would fix the vibration through the steering wheel, occurs when I go over 60mph and gets unbearable over 100mph (private roads...........) but it hasn't fixed it.
I then thought it might be the wheel balancing, so had a couple of new tyres fitted, all the wheels balanced and shifted the wheels front to back, No change, it's still exactly the same as it was before.
Has anyone had a similar problem??
Any suggestions??
Old Apr 9th, 2009, 08:58 PM
Local Time: 12:52 PM
I cannot see why anyone would just change one bush??! they have both done the same mileage!
Old Apr 9th, 2009, 09:36 PM
theone's Avatar
I was of the same opinion but i saw them, the rubber on the bush on the drivers side was perished and split, the one on the passenger side was perfect.
beginning to wish i'd got them both changed though...... rule that option out if nothing else!
still wondering about wheel allignment, track rod ends etc etc
Old Apr 9th, 2009, 09:59 PM
Weemann's Avatar
England Male View Weemann's Pure Silver & Body Color 1st Gen MINI One Profile
wheel bearing could be going... mine did that big time when that happned, if it is the case u wanna get it sorted asap
Old Apr 15th, 2009, 07:22 AM
United Kingdom View mini_rab's Classified Ads
Had the same problem with vibration had tracking done twice and balancing but then local alloy wheel dealer suggested the locator ring inside the center for alloys worn or missing they where missing prob cos i bought second hand alloys may have fell out or still been around the hubs of previous owner. hope i've explained this, they are a ring that sits inside the alloy wheel center and then locates around a lip in the wheel hub, might not be the problem but may help someone else
Old Apr 15th, 2009, 08:17 AM
Keano's Avatar
JCW 250
United Kingdom Male View Keano's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Keano's Classified Ads
Cost much to fix this?
Running 211whp
Old Apr 15th, 2009, 12:45 PM
jamski's Avatar
'Jack the Black' Cooper
Send a message via MSN to jamski
United Kingdom Male View jamski's Cosmos Black & White 1st Gen MINI Cooper Profile View jamski's Classified Ads
Getting my rear wheel bearing done today!! Part is £118 and about an hours labour I think. I'm getting the part from Mini but not fitted there!!
Old Apr 15th, 2009, 02:15 PM
Keano's Avatar
JCW 250
Thanks for that If you were to get it done by BMW then that would add another £100 on top i would imagine !!! Looks like its about £150 all in then...
Did you have any of the symptoms mentioned above?
Running 211whp
Old Apr 15th, 2009, 04:06 PM
theone's Avatar
Surely Genuine Mini wheels don't have Spiggot rings/locator rings in them?
They'd only ever be used to get an aftermarket set of wheels to fit a standard hub?
My car's running it's 15inch genuine Mini wheels (sold my R90's last week) :-(
I had all the tyres ballanced last week and there's still vibration in the steering wheel from 60 MPH upwards.
Guess it's either a wheel bearing or a bush?
Old Apr 15th, 2009, 06:07 PM
Countdown's Avatar
Standard wheels wont have spigot rings.
mmm im still going going for wheel balancing , maybe the sticky weight has fallen off after geting them balanced or something, or maybe the machine wasnt calibatred correctly, or maybe the tyre fitter was a lazy *** and just didnt bother - i'd take the wheels else where and check the balancing again.
with those symptoms i'd say there was something more likey wrong with the wheels than bushes or bearings....strange one though. Let us know if you get it sorted.
Old Apr 15th, 2009, 06:17 PM
theone's Avatar
I know what you mean but the guy who fitted my tyres has been doing it for years, real car enthusiast! the weight havent fallen off as it was like this both before and after fitting the new tyres. Need to save up some pennies and put it into the garage for further inspection, it's beyond me!
Old Apr 15th, 2009, 06:36 PM
Countdown's Avatar
stumped me as well, check its clean where the wheel makes contact with the hub. Any local mini owners near by? trying swapping the front wheels and see if its the same, rule if its the car or wheels?
Old Apr 15th, 2009, 07:07 PM
theone's Avatar
That's true, should have tried that before I sold my other wheels last week!
Will keep you posted, I'll get it in the garage soon if i can't find anything myself
Old Apr 15th, 2009, 10:28 PM
jamski's Avatar
Only had a small drive back from having the rear bearing replaced but it's made a huge difference. The noise has gone and overall the ride seems smoother and quieter.
I was shown the old one and could hardly turn it, really really notchy, should be nice and smooth.
If that was on a front wheel I would imagine you would feel it through the steering wheel!
  #15 (permalink)
Old Apr 16th, 2009, 09:36 PM
theone's Avatar
Glad you got your car sorted. I don't think mine's a wheel bearing issue, there's no noise or give away signs of the bearings on my car being damaged. I think I'm just goin to have to put it into my local garage for further inspection :-(
Who know's what's up with it.
vibration and knocking through steering wheel Max Stetson First Generation Faults & Fixes 2 Apr 27th, 2006 10:28 AM
Steering wheel vibration, cames with car pulling right? Mini_Jen Wheels, Tyres & Brakes 9 May 31st, 2005 07:17 PM
Vibration from steering wheel pflowers First Generation Faults & Fixes 16 Jun 22nd, 2004 06:13 PM
Is this kind of steering wheel vibration normal? nullspace First Generation Faults & Fixes 7 Nov 10th, 2002 12:46 AM
Steering wheel vibration. SCOTLAND YARD First Generation Faults & Fixes 3 Oct 17th, 2002 01:18 PM
