» Sponsors
» Sponsors
Go Back   MINI2 - MINI Forum > MINI Technical Forums > MINI Faults & Fixes > First Generation Faults & Fixes
MINI2.com is the largest MINI Forum on the internet. Registered Users do not see the above ads.
Old Apr 21st, 2009, 03:17 AM
erniec
Local Time: 07:18 AM
Australia
Is this normal engine temperature on my r53 mcs???pls help
I just bought a 2nd hand 2005 mcs with a mileage of 38500kms. The thing is recently ive noticed that the temperature gauge says the engine temp is about 90 degrees but the owners manual says the normal running temp should be around the half way mark which is abt 60 degrees. I am very worried as this is my first mini.. Pls help me out cheers..
Old Apr 21st, 2009, 10:19 AM
ScottyBoy's Avatar
ScottyBoy
Obsessive Car Cleaner OCC
Local Time: 10:18 PM
United Kingdom Male View ScottyBoy's Solid Black & Body Color 1st Gen MINI Cooper S Profile View ScottyBoy's MINI Profile Images
Where does the needle sit on the the tempreture gauge? if it sits half way and does not move then that is fine.
Scotty
Old Apr 21st, 2009, 12:57 PM
erniec
Australia
hey scotty its at about the 3/4 mark. thats why im worried. the manual says it should be at the half way mark.
Old Apr 21st, 2009, 01:09 PM
MINIAC's Avatar
MINIAC
MINI Profiler
Local Time: 01:18 PM
United States Male View MINIAC's Dark Silver & White 1st Gen MINI Cooper S Profile View MINIAC's MINI Profile Images
90 degree Celsius is 194 degree Fahrenheit, which is normal operating water temp.
Old Apr 22nd, 2009, 12:31 PM
erniec
Australia
hey thanks alot. I was just worried because the owners manual said the temperature gauge reading should be at the half way mark which is around 60 degrees. i got 90 degree celsius. So does that mean the owners manual is kinda inaccurate??
Old Apr 22nd, 2009, 01:04 PM
Morri7's Avatar
Morri7
Local Time: 09:18 PM
Scotland Male View Morri7's Indi Blue & White 1st Gen MINI Cooper S Profile
I think it sounds like the gauge is in accurate. Like MINIAC said I think 90 C is normal and this is the temperature that the gauge should sit in the middle. Check you have enough coolant in the system to be sure that it is not running hot because of this.
Old Apr 22nd, 2009, 02:16 PM
erniec
Australia
hey my middle mark is 60 degrees and urs is 90 degrees.. is it because mines the chrono package?? i highly doubt so..anyway i guess as long as the light doesnt come up im good to go. anyway im taking it to mini for service soon..thanks heaps..and another thing..my coolant tank has darkened..do u think i need to change it?? cuz i cant see anything inside unless i open the cap.
Old Apr 22nd, 2009, 03:43 PM
MINIAC's Avatar
MINIAC
MINI Profiler
Get a Scangauge so you know exactly what the temp is
Old Apr 23rd, 2009, 08:09 AM
Putsy
Menace Motorsport
Australia
A chrono package will sit at about the 3/4 make which is realy 90dec C and a standard gauge will sit smack bang on half way.
Old Apr 23rd, 2009, 08:22 AM
erniec
Australia
Australia
hey thanks alot..i was suspecting the differnece lies in the chrono package but anyway thanks for verifying it..cheers mate..
Old Apr 24th, 2009, 12:21 AM
canned_heat
Just to say that my '05 MCS with chrono pack sits on 90degrees too. The needle sits vertical (3/4) when up to temperature.
Old May 7th, 2009, 11:37 AM
Riggy
Thanks from me as well, I was also wondering about this. It's something I noticed on the test drive. I like the extra info you get from the chrono pack but I kind of miss the massive speedometer.
Old Jun 5th, 2009, 09:04 AM
eliont
Local Time: 02:18 PM
Canada
Water temperature for mini cooper
Thank you guys for the information. I was wondering why was my temperature gauge closer to 200 F or 90 C degrees. The gauge was pointing straight up (vertically upwards.) I was concerned because that was almost 3/4 of the way. I had the impression that the engine was overheating. Reading from the previous posts, I am now calm because it is just the chrono dial version that has the normal operating temperature at 3/4. I suppose that 90 C is a good water temperature as stated previously from others.
Old Aug 5th, 2009, 01:16 PM
Dumboo
Hi all
Can I just to make 100% sure that the coolant temperature on the Chorno pack gauge is 90-95 degree C (3/4 of the way up?) I have recently bought this car and am worry the temperature is too high....may I have a photo showing the correct position when the engine is warmed up? I can not find any on the web, I shall take one myself when I get back, am travelling for work at the moment.)
Mine is a Cooper S. Thanks in advance...
  #15 (permalink)
Old Aug 5th, 2009, 01:49 PM
DaFlake's Avatar
DaFlake
MMC Member
Local Time: 04:18 PM
If you read the above you will see that 90 to 95 is ok.... Operating temp according to my scanguage is 195 F.
Engine temperature gauges at full!! KJ_daGreenMini First Generation Faults & Fixes 3 May 26th, 2008 11:34 PM
normal engine running temperature garyb1 First Generation Faults & Fixes 3 Apr 17th, 2008 02:15 PM
Engine temperature below normal! mlt First Generation Faults & Fixes 7 Jun 3rd, 2007 09:15 PM
No engine temperature gauge Stormbreaker Second Generation Faults & Fixes 31 Jan 23rd, 2007 02:47 PM
Engine bay temperature? -=cHiLli=- First Generation MINI Tuning 4 Aug 15th, 2006 03:02 PM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
