lambda sensor Hi can anybody help me My emisions light came on recently so got my brother in law to take it to his work and hook it up to the computer at his garage. It said O2 sensor 1 no good so i got him to order a new sensor from BMW.This was fitted but once restarted the light is still on cant get back to the garage for a week. Anyone any ideas? |
| What is the build date of your MINI? |
| you need to understand that because a code reader says there is a fault in a circuit then the whole circuit need to be tested :- ie o2 fault does not mean that the sensor is faulty you have to check signal and feed , check the ohms at the o2 sensor then look at what controls it , for instance is the coolant temp sensor ok, are there any air leaks is there a weak spark at a plug ,is the injector opening to long. proper diagnostics my take time but save ££££ if done right. |
| Tags: sensor |
| LAMBDA SENSOR got cut off wiring ?? | GuppySingh | Second Generation MINI Tuning | 3 | Dec 21st, 2008 09:40 PM |
| Lambda emulator | AlexFW | First Generation MINI Tuning | 4 | Sep 4th, 2008 05:01 PM |
| Argh! Convertible Roof and Lambda sensor problem | spinout | First Generation Faults & Fixes | 4 | Jul 24th, 2008 01:24 PM |
| Both my Lambda sensors have failed! | ashton | First Generation Faults & Fixes | 6 | May 26th, 2006 04:44 PM |
| Brake Light Sensor & Sensor replacement help needed | wrxtomini | First Generation Faults & Fixes | 7 | Apr 20th, 2006 07:55 AM |
