| The whining sound is the thrust release bearing, they all make that noise, quite normal (all three of my minis make that sound). The knocking sound is possibly because it is a short wheel base and it will rock back and forth etc if you pull the clutch out too quickly, all to do with power to weight. My wife does it all the time. ![]() I am sure if I am wrong someone will be along to give a more accurate diagnosis, but to be honest I don't think you have anything to worry about. |
| Yes I ge that knock when pulling off or in rev. I dont think its meant to do that but the car has been into mini for a service and they didnt say anything about it. Oh yes its when you left the clutch up to quick..... The one and only Cheeky Mini |
| Jusy seen a mate of mine who is a bit of a gear box man in the A1gp race series, and he says it doesn't sound too bad!! thinks its probably just the oil spinning the gears on the lay shaft ![]() Clubbin' it and Lovin' it |
| As I said before, all three of my minis whine, and so it's either a common thing, or I have three expensive problems. |
| Tags: gearbox facelift |
| Clutch/ Gearbox noise Cooper D | markslater | MINI Cooper Diesel | 7 | Apr 3rd, 2012 04:32 PM |
| 52 plate cooper noisey gearbox | carl_a | First Generation Faults & Fixes | 1 | Nov 22nd, 2007 08:41 AM |
| gearbox noise cooper s | mowgli uk | First Generation MINI Tuning | 3 | Jun 29th, 2006 11:02 AM |
| Poll : Cooper S gearbox noise | northandy | First Generation MINI Cooper S | 58 | Jun 24th, 2005 11:46 AM |
| a new noise on my 05 cooper gearbox, i think?? | flav | First Generation MINI Cooper | 0 | Nov 10th, 2004 09:56 PM |
