dry coolant tank advice? Hello all, I'll warn you now, I don't speak car! I'm at my wits end wth my Cooper S. I saved up and bought an 05 plate last summer- My main problem at the moment is the coolant tank, it ran completely dry about three weeks ago an the thing started to smoke up and I had to call the AA out, the guy took something off, I think called a 'T' and I need to replace it, my coolant tank hose now has to metal pull rings keeping it in, it worked just fine for a bit, but just yesterday and today I've had to re-fill the tank with water as it's just empty- I'll only have to drive a few minutes and the car starts making a very loud sound-like a hoover and then I hear a slapping sounds from by the passenger foot side-I don't know what the problem is and I've already been royally ripped off by the Cooper garage so thought 'd chance a post incase someone was kind enough to help me out-I just need to know what I need to replace. Any advice?? Thanks so much, Holly |
| The 'hoover' noise you are hearing is the fan that comes on when the radiator is unable to cool the engine effectively. More importantly however, you shouldn't be putting water into the the radiator, you need to get some BMW approved Anti-Freeze and Anti-Corrosion coolant, which you mix 50/50 with water. This happened to my 03 Cooper a while ago, the radiator was leaking and needed to be replaced. |
I'm not using it right now, I just need to know what parts to order- the stephen james cooper specialists near me completely ripped me off in October with a small problem with the back window wiper-it wasnt fixed correctly and i had to pay out again only three weeks later and they were no help at all when i called them and explained i'd only just had it done-plus they quoted me £1,248 to fix my bumper (just a small dent) and i got that fixed privatly for £110, needless to say i have no faith with them whatsoever. I'm in South-East London Also wasnt just puttin the water, got the anti freeze stuff and mix that 50-50 Last edited by MINIAC; May 2nd, 2009 at 11:52 PM. Reason: Merge consecutive posts |
| Tags: please help |
| Do you have a coolant tank leak? | Tom F. | First Generation Faults & Fixes | 48 | Dec 11th, 2010 11:03 AM |
| coolant tank and heat... | crazyaboutmini | Maintenance & MINI Care | 0 | Apr 27th, 2006 05:51 AM |
| Is there a way to empty the coolant tank? | S33BBY | First Generation Faults & Fixes | 10 | Jul 13th, 2004 10:36 AM |
| Coolant tank replacement??? | Faat | First Generation Faults & Fixes | 4 | Jun 6th, 2004 11:38 PM |
| Coolant Tank Dealer help? | KenBond | First Generation Faults & Fixes | 10 | Mar 17th, 2004 09:49 PM |
