| Engine coolant topping its self up!! :S:S:S Hi ive just had my thermostat and thermostat housing replaced as i was loosing engine coolant. I checked my engine coolant today and it had dropped again however when the car has reached halfway on the temperature gauge the coolant is back upto max again!! i am confused as to why it is doing this? any help would be appreciated. Thankyou |
| Sounds like it should... This is due to expansion from heating of the coolant. Here is a good read. Automobile Engineering Basics:What is a Pressure Cap and Expansion Reservoir in cooling systems? You should be checking the coolant level when the car is hot to ensure that you are not over filling it. |
| Engine Coolant | benjiboy8000 | Maintenance & MINI Care | 13 | May 1st, 2009 12:38 PM |
| Engine Coolant? | benjiboy8000 | First Generation MINI Tuning | 5 | Feb 13th, 2009 12:02 PM |
| changing engine coolant! | bemini | First Generation MINI Tuning | 7 | Jul 19th, 2006 10:21 PM |
| Topping off the coolant | scottwkurth | Maintenance & MINI Care | 3 | Dec 11th, 2002 10:12 AM |
| Topping up Coolant with water??? | elmadi | Maintenance & MINI Care | 14 | Oct 30th, 2002 09:42 AM |
