Xenon Headlight Fault, Always on pointing at the ground - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 6th, 2009, 01:59 AM
Local Time: 07:53 AM
United-States Xenon Headlight Fault, Always on pointing at the ground
I recently replaced the battery in my 2005 Cooper S (USA). Afterward I noticed that the headlights turned on as soon as I turned the key on. However, the headlights do not fullly level when they are on. This model does have the option of selecting the headlights to automatically turn on in low lighting, but the switch is off. I cannot turn the lights off with the light switch. The light switch on the turn signal does nothing.
I disconnected the battery from the car and let it reset itself, but the fault is still there. Xenon's aren't much good when they point only at the ground!
Can anyone tell me if there is a reset specifiaclly for the lights. Or is there a previously described sensor failure that I can replace.
Thanks in advance.
Tags: , ,
Xenon Headlight broke? Kryptonic First Generation Faults & Fixes 19 Mar 4th, 2009 08:16 AM
Xenon Headlight Replacement Subiklim First Generation Faults & Fixes 9 Feb 9th, 2007 12:28 AM
Intermittent Headlight Fault mtuk First Generation Faults & Fixes 2 Oct 7th, 2004 04:20 PM
Xenon Headlight Upgrade caminifan First Generation MINI Exterior 1 May 28th, 2004 12:58 AM
HELP: xenon headlight removal Sharkey Maintenance & MINI Care 0 Nov 5th, 2003 03:59 PM
