Temperature Gauge Redux - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 18th, 2002, 10:46 PM
Send a message via ICQ to tscheez Send a message via AIM to tscheez
Local Time: 08:54 AM
i know I have posted this here before but I am having probs with the temp gauge again. The gauge is sitting 1/4 notch above center and I'm the kind of person who wants to try to fix things myself.
Anyone out there who has fixed this on their own or knows where to look around the engine to find the connector or sender unit? I do have a MCS so there is a supercharger in the way!
Any help would be great, Thanks
Jake
PS I'm not worried that it is running hot. the gauge sits between 0 and 1/4 when the engine is cold.
Old Oct 19th, 2002, 09:15 AM
MICKEY's Avatar
Local Time: 01:54 PM
United Kingdom View MICKEY's Chili Red & Black 1st Gen MINI Cooper S Profile
Still playing up ?????????????/
Can't help on were the sender block is housed as I let the dealer do all my work for me (that’s what a warrantee for)
Have you tried going to the dealers and having a chat with one of the mechanics ????
Old Oct 19th, 2002, 05:08 PM
Local Time: 12:54 PM
hi tscheez
Im not 100 percent about the MINI'S but on BMW'S the temp guage is heavily damped...by this i mean any temperature between 72 degrees and 112 degrees the temp guage will always sit in the 12 o'clock position(straight up) anything under or over and the guage reacts accordingly eg cold or hot...
cheers guys i hope this helps...i feel the fault could be a dodgy temp sensor...
The LED will illuminate at coolant temperaturs of approximately 120 degrees c
Old Oct 19th, 2002, 09:24 PM
Oh well, I'll have to get it looked at.
on a good note only 100 more miles untile the odometer shows 1200.
Old Oct 22nd, 2002, 06:06 AM
Hi
The sensor is located underneath the thermostat housing.
The sensor is used to monitor the engine coolant temperature and has two wires
both connected to the EMS 2000. The signal is also used
to control the radiator fan speed as well as supplying a signal on the
CAN-bus to drive the coolant temperature gauge in the instrument
cluster.
No engine temperature gauge Stormbreaker Second Generation Faults & Fixes 39 Apr 11th, 2011 08:38 PM
temperature gauge question girasole General Discussion 14 Nov 3rd, 2005 10:06 PM
temperature gauge!! ollie c First Generation MINI Cooper S 5 Apr 20th, 2004 08:17 AM
How do I reset the outside temperature gauge? TrueBrtOhio First Generation Faults & Fixes 4 Feb 10th, 2004 11:52 AM
Is Temperature Gauge OK? crunchie First Generation Faults & Fixes 7 Dec 14th, 2002 10:58 AM
