Electric motor whining noise ? Fixed ! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 27th, 2009, 08:26 PM
Vrooom
Local Time: 11:03 PM
So I'd just come to a stop at some traffic signals and a couple of seconds later I heard what sounded like a relay click in followed by what sounded like an electric motor starting / running with an 'iffy' bearing.
I turned off the AC and any other likely sources but to no avail.
After a few 10's of seconds it went away.
It seems to be pretty repeatable but have not been able to isolate the problem - even though it's quite loud under the hood / bonnet.
The pitch / speed of the motor sounds more or less constant despite engine RPM, but does go up a little with RPM - I suspect because the battery voltage increases a bit.
EDIT - It's the electric cooling fan(s) - doh !
Sounds like a bearing might be on the way out on one of the motors...
Chilli Red '05 MCS - pocket rocket *** Colbalt Blue '03 911 Twin Turbo - intergalactic rocket
Lexus RX400h 4x4 - hauler *** VW Beetle GLS - shopping cart
Tags: , , , ,
Whining/rattly noise - possible gearbox? Horatio First Generation Faults & Fixes 5 Apr 19th, 2009 09:18 AM
Whining squeaking noise Barbados Mini2k2 First Generation Faults & Fixes 3 Feb 5th, 2009 11:23 PM
whining noise when driving BlackEyedPea First Generation Faults & Fixes 8 Nov 27th, 2008 10:14 AM
Whining from steering motor on 52 plate Cooper scooby657 First Generation Faults & Fixes 8 Apr 21st, 2006 08:07 AM
whining noise muisje S First Generation MINI Cooper S 9 Oct 23rd, 2005 10:32 PM
