| How can i get my broken dip stick out (no rude comments) My dip stick has broken the top came off and now i can not get it out any ideas how i can get this out. Yes i am sure you all have some comment to make but please i have to guess the oil level at moment. Thank you. Gill |
| Hi Gemm, Not sure how much you can see of the dipstick but you may be able to buy some long nosed pliers which you could use to pull the dipstick out if you can see enough of it. The other option is to remove the bumper and pull the radiator to one side and take the actual tube in which the dipstick slides into off the engine block - all depends how comfatable you feel with removing the bits - they are pretty easy to take off. hope this helps. |
| Here is a schematic if you have to remove the tube. Good luck. 06 MCS PW/B, 15% pulley, JCW CAI, ALTA 22mm rear sway bar, DINAN front strut tower brace, custom air diverter plate, original owner. |
Problem Solved I had the same issue with my '05 MCS last month. I was able to pull out my broken dipstick using a "grabber tool" I had in my tool box ($2.49 at the local tool store). The grabber tool ends needed to be modified with some needle nose pliers. If you take the pliers and gently bend the claws at the tips inward so that they point back inward toward the center you will have a pretty effective claw for for grasping the broken dip stick to pull it out. You will have to visualize a bit from the drawing. I didn't have to remove the oil pan or remove the front end. A pretty simple procedure that took a little patience but in the end worked and the broken dipstick was pulled out - see attached photos |
| Dip stick in the cooper s | skay98 | First Generation MINI Cooper S | 6 | Feb 9th, 2009 12:54 PM |
| Dip stick design | tiger333888 | Second Generation MINI Cooper S | 13 | Jul 30th, 2007 08:56 PM |
| Light washer stick measurer broken | IH1 | First Generation Faults & Fixes | 0 | Feb 18th, 2007 11:21 AM |
| Strange Dip Stick Reading | Benay | First Generation Faults & Fixes | 4 | Dec 4th, 2006 08:39 AM |
| Checking Oil, Pain in the Dip Stick! | JG.26 | Maintenance & MINI Care | 3 | Jun 22nd, 2004 01:20 PM |
