Stuck Boot - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 6th, 2009, 09:53 PM
Local Time: 11:31 AM
United Kingdom View cooper-s-tom's Classified Ads
Stuck Boot
As the tittle suggests my boot is jammed shut. Has anyone else has this problem? It appears that the release mechanism has failed I'm going to take the boot panel apart tommorow is there anything I should look for?
Old Jun 9th, 2009, 06:09 AM
Hi
I had the same problem, electronic release would intermittenly stop working. I was forced to use the manual release (under rear seat base) for weeks and ultimately did same as you, stripped boot panel away and had a fiddle around, miraculously it worked again.....for about two days before packing in.
Mine wixed under warranty and had a complete rear boot grip/handle as was advised you cannot buy just the electronic switch on its own!!! Others may well correct me here but that's dealers for you, why repair when can completely replace.
Try a breakers yard or mini tuner who may have an old boot grip you can strip down, would be easier than getting new grip and having it painted to match car etc.
Hope that helps
car boot stuck iwantamininow! Second Generation Faults & Fixes 18 Mar 25th, 2009 08:57 PM
Help Please! Boot handle connector disapeared inside boot Suzi First Generation MINI Exterior 2 Apr 6th, 2006 06:04 PM
Boot light on in car, but the boot is closed! bryfliesme First Generation Faults & Fixes 5 Apr 29th, 2004 05:56 AM
Boot Trays and Boot Mats ??? Torino Paul General Discussion 1 May 12th, 2003 08:44 PM
