coolant steam! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 8th, 2009, 10:43 PM
Local Time: 11:31 AM
United Kingdom View lowrider's Classified Ads
DIY coolant steam!
After a sporty drive home tonight I parked up to find steam coming form the coolant overflow tank,around the cap.Whilst this was happening the temperature sensor remained unchanged(in the middle) It settled after I switched off the engine and even though it steamed heavily the coolant level has not altered much.
Help
Old Jun 8th, 2009, 10:52 PM
shent9's Avatar
matt
Send a message via MSN to shent9
United Kingdom Male View shent9's Classified Ads
tighten the cap?
Old Jun 9th, 2009, 05:56 AM
Cap is on tight.It is a push down(not screw type)
Old Jun 9th, 2009, 07:52 AM
ScottyBoy's Avatar
Obsessive Car Cleaner OCC
Local Time: 12:31 PM
If you have slightly to much in there this will happen. aslong as the temp gauge does not move above normal then you will be fine.
Even with a screw cap on an MCS this happens my coolant tank is always discoloured
Old Jun 9th, 2009, 08:47 AM
cars-r-me
United Kingdom Male View cars-r-me's Classified Ads
There is a common fault with the bottle ,The seam splits round the middle of bottle were it's stuck together
Old Jun 9th, 2009, 06:30 PM
Checked the expansion tank this morning. It was empty! Filled it to max and drove to work. empty again. Filled it and it stayed at the max level but when I drove home and parked the coolant started to bubble from the pipe connected to the bottom right of the expansion tank the coolant level rose and it started to boil over.I switched off the engine and it settled but there is now coolant right up to the cap.After a few hours this dropped to the min. level. Could this be an air lock? Advice appreciated
Old Jun 19th, 2009, 07:19 PM
BJM
Scotland View BJM's Solar Red & Body Color 1st Gen MINI One Profile
Could be a knackered thermostat.
When the engine is hot - is the radiator also hot?
Old Jun 19th, 2009, 07:22 PM
PK5
I agree with bjm, do a check on the thermostat
Tags: ,
Steam! Help! Please sportdan First Generation Faults & Fixes 20 Mar 5th, 2008 12:17 PM
Coolant leak with steam oldnell First Generation Faults & Fixes 5 Jul 5th, 2007 05:22 PM
Steam????? GCoopS First Generation MINI Cooper S 6 Oct 7th, 2006 12:52 PM
White steam mrsw First Generation Faults & Fixes 8 Jun 14th, 2003 03:37 AM
Steam under bonnett Hotelcalif First Generation Faults & Fixes 8 Dec 30th, 2002 08:21 PM
