| Steering wheel vibration/shaking during high speed braking Hi all, I seem to have a problem whilst braking at high speeds with my 2002 (52) first gen Mini Cooper. When going approximately 70-90 at high speeds and then braking (gently, but not lightly), the steering wheel shakes vigourously until the car has completely stopped decelerating. Is this a known problem? Should I ensure the wheels are balanced? Thanks. |
| A couple of things you could try, 1 is to check right pressures in tyres, check wheel bearing by grabbing the wheel and see if it wobbles. then go to tyre fitter to check the balance of wheels. When did you last have a service as you might need brakes looking at? |
| If it only occurs under braking, I'd also be inclined to suspect the brake discs. All the best, Andrew. NeuroBeaker - Proud owner of Zeus (a 'modestly modified' 2004 MINI ONE). Helpful Links: [1st Gen. Power Steering Pump (PSP) Failure Guide] [1st Gen. PSP Repair] [Thread Titles] [Adverts Fix] |
| Tags: braking, high, shake, shaking, speed, steering, vibration, wheel |
| Steering wheel/column vibration | bazzer79 | First Generation Faults & Fixes | 2 | May 29th, 2009 08:53 AM |
| Vibration in steering wheel | theone | First Generation Faults & Fixes | 24 | Apr 19th, 2009 06:30 PM |
| vibration and knocking through steering wheel | Max Stetson | First Generation Faults & Fixes | 2 | Apr 27th, 2006 10:28 AM |
| Vibration from steering wheel | pflowers | First Generation Faults & Fixes | 16 | Jun 22nd, 2004 06:13 PM |
| Steering wheel vibration. | SCOTLAND YARD | First Generation Faults & Fixes | 3 | Oct 17th, 2002 01:18 PM |
