cooling system..is this normal Hi guys n gals need some advice, ive got an 06 cooper cabrio in th elast few days ( when its been hotter outside ) ive noticed my fans staying on for 2-3 minutes after i switch off from going to work a journey that takes 30 mins of b road driving. This am ive started up the car on the drive and kept the revs at 2000 to get the temp up. The needle stays at midway on the temp gauge and the fans cut in every few minutes for about a 10 second burst the temp gauge doesnt move, ive unscrewed the bleed plug on the elbow piece hose that leads from the rad to engine and coolant water comes out, does this prove the pumps working ok? the fans continue to cut in every few minutes for 2-3 second bursts for ever, i assume this is correct? however whilst im driving i can sometimes hear the fans cut in similar to that when i get at work ie a 2-3 minute fan cycle every 10 minutes or so, is that commen in hot weather? I asked my local mini/bmw garage about it and they just ask me to book it in for a diagnostics but thats going to cost me £90 before they even do anything. btw its out of warrenty at the end of this month ! Am i being paranoid or is this behaivour normal for the cooling system? many thanks for your help |
| if your not losing coolant and the temperature gauge is not in the red I wouldn't worry. in the hot weather the engine fans do work a bit overtime, especially when idling. |
| thanks for that i guess im being a bit paranoid then huh still ive booked it in with the garage to look at it for next friday as the warranty runs out at the end of th emonth then if they find something itll be covered |
| ok as an update it went into stratstone maidenhead on friday and it has a leak from the thermostat area and the thermostat is on its way out they also found a slight leak from the power steering house so that all being done under warantee thank goodness, altough they did try to flog me new tyres all round and new front pads n discs meahhhhh |
| I got a phone call today and was told that BMW would pay the following.... 1. Thermostat - 100% parts & 80% labour = £26 + vat payable by me 2. PAS - 100% parts & 50% labour = £76 + vat payable by me Not bad. Will be able to do the pads myself at a fraction of the cost and there is still about 6 months use out of the rear tyres. |
| Tags: cooling, fans |
| Problem With the cooling system | Woolly44 | First Generation Faults & Fixes | 5 | May 31st, 2008 05:54 AM |
| Cooling System Problem | nomis | First Generation Faults & Fixes | 2 | May 30th, 2008 08:55 PM |
| Leak in engine cooling system | PeterModin | First Generation Faults & Fixes | 8 | Mar 21st, 2008 05:08 PM |
| Bleeding points in the cooling system | Mini_Turbo | Maintenance & MINI Care | 3 | Sep 12th, 2003 09:14 AM |
| Intercooler Cooling System | scm6079 | First Generation MINI Cooper S | 1 | Aug 27th, 2002 05:36 PM |
