90 minute run at 75mph = cold radiator? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 18th, 2009, 03:11 PM
Cooper Man's Avatar
"Just Like That!"
Send a message via MSN to Cooper Man
Local Time: 12:32 PM
England View Cooper Man's Chili Red & White 1st Gen MINI Cooper S Profile
I have a Jun 03 MCS that has covered 180k miles and is suffering the "slight loss of light-brown coolant from the header tank" problem ...and has been for a while, and gets topped-up regularly. So I am planning to flush the system and replace the coolant and cap, and possibly the thermostat and housing.
BUT, I was poking about under the bonnet today after an 80 mile drive and noted that the header tank was "hot", the radiator top and bottom hoses were "warm", but the radiator was cold, not even luke-warm!
I didn't even think about touching the block, but I suppose I should have done ...I can try that one later.
The car is performing well, no smoke/steam from the exhaust, no emulsion in the oil, no puddles on the floor, the air-con and heater work well, so I am a little bit confused.
I don't hear the fans come on that often, so the car isn't overheating as such, despite the slight loss from the header.
So I believe that there must be a blockage somewhere - could it be the thermostat failing to open/close?
UJ Club: GB064
Old Jun 19th, 2009, 07:12 PM
BJM
Scotland View BJM's Solar Red & Body Color 1st Gen MINI One Profile
Hot block and cold radiator is a common sign that the thermostat has failed.
My other half mini One has the coolant leak problem and this afternoon I've taken the Thermostat housing off as it appears to be leaking. It took me about an hour.
I'd say that if your going to be changing the housing then your silly not to do the thermostat at the same time. You can also do a kettle test to see for sure if the stat is gubbed.
What does your temp gauge say?
Old Jun 30th, 2009, 10:47 AM
Cooper Man's Avatar
"Just Like That!"
Temp gauge? What's that? My S has the OE satnav, so luxuries like a water temperature gauge were done away with by the designers.
I have fixed the problem ...by simply fitting a new cap to the header tank.
I've got a new thermostat and housing lined up, ready to be fitted once I have some reasonable gauges to fit a new instrument pod I have recently bought. A temp gauge is on the agenda, and considering how much stuff has to be removed to get to the sender unit/thermostat area, it'll all be done in one go.
UJ Club: GB064
Tyre replaced - now have vibration above 75mph R99 Wheels, Tyres & Brakes 12 Feb 14th, 2007 07:00 PM
Dales Run 2005 - last minute! March 20th bards UK & Ireland Discussion & Event Planning 292 Mar 25th, 2005 10:17 PM
What Happens to Sunroof Mode @ Greater than 75MPH? lattehiatus First Generation MINI Convertible 7 Sep 12th, 2004 03:23 AM
Last Minute Brecons Run - Sunday 11th April kazmire UK & Ireland Discussion & Event Planning 14 Apr 11th, 2004 05:15 PM
Lake District Mini Run 13-15th June, last minute entries Text 07770454545 mikeythemini UK & Ireland Discussion & Event Planning 27 Jun 18th, 2003 09:07 PM
