| it is possible to drive the car, but it your power steering pump has gone by the sounds of it. I would refrain from driving it if possible, but have you turned the car on again? You may find that it is an intermitten fault and it may work again, but it will need replacing. |
| power steering pump has stopped working. common fault on the older MINI. Depending on milage BMW often offered to halve the costs...eg they pay for part you pay for labour if the car was low milage. Not always but has happened. YOu can drive the car but its very difficult. The faster the tyres rotate the easier it is to turn but even then its major muscle time and if its stopped or low speed it is almost impossible unless your reasonably strong. Should not burn the engine out or anything...its an electrical part with its own fluid. However some failures are caused by shorts and the heat from the faulty pump has been known to melt wires and start fires in rare instances. R This is the most unprofessional bit of site management I have seen since I was banned from a certain other site...at least they had the excuse that they were enthusiasts who had strong views and not professionals paid to keep thier cool! |
| Tags: power steering |
| Grr :Ticking MCS works...questions, safe to drive etc | bimini | First Generation Works | 3 | Aug 16th, 2005 11:59 AM |
| What a safe little car thank god! | petew | General Discussion | 28 | Sep 12th, 2003 01:44 PM |
| Dads turn to Drive | CoopeR | First Generation MINI Cooper S | 1 | Aug 5th, 2002 09:47 PM |
| Is the MINI a safe car? | coopercrazy | General Discussion | 4 | Jan 25th, 2002 09:27 AM |
