Air con light flashing - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 30th, 2009, 09:41 AM
Local Time: 12:33 PM
England Air con light flashing
I've just recently bought a 2002 (52) Mini Cooper from a private seller, and when I press the air con button the green light comes on then starts to flash and the air con doesn't get cold
Any ideas how to fix this or how much it'll cost me to fix this?
Old Jun 30th, 2009, 09:56 AM
still learning
Scotland Male
is your heater fan turned up and/or is it working properly ?
Old Jun 30th, 2009, 11:51 AM
Cheers for the comment, what happens is I have the far left dial on blue and the middle dial on 2 or 3 and the position pointing towards me e.g. ->
When I press the air con button the green light comes on then after about 1 second or so, it starts to flash and the temperature does not get cold.
Old Jun 30th, 2009, 04:48 PM
MINI One Seven
United Kingdom Male View M.O.S's Pepper White & Body Color 1st Gen MINI One Profile
Needs a re-gas by the sounds of it. Not too expensive
The Original MINI One Seven
Yorkshire MINI Register - PM for details
Old Jun 30th, 2009, 05:50 PM
PK5
When you start the car does your car go through a program check. ie do all the lights and that light up and then go out?
Old Jun 30th, 2009, 06:41 PM
Cheers for the comments all.
In response to PK5 it's a case of when I press the air con button it goes green then begins to flash.
When I start the car, I've not noticed anything apart from on the odometer it says service due in xxxxxx miles.
Does anyone know where I can get it re-gassed, at a reasonable cost? (If that is the problem/cure)
Old Jun 30th, 2009, 07:07 PM
United Kingdom View njh123uk's Pepper White & Black 2nd Gen MINI Cooper Diesel Profile
I had this problem on my 56 Mini One D. Turned out there was a broken wire behind the bumper (which powers the air con). Fortunately this was repaired for me because the dealer had broken it in the first place.
Might be worth a check that nothing's been removed from the front of the car? Failing that a gas replacement is probably what you need. Mini charge around £100 for it. When mine was repaired the dealer was happy to refund my £100 if the recharge didn't fix the problem - it's hard to prove if the gas needs replacing without actually replacing it!
PK5
normally around £35.00 to regass, look in local paper or ask local garage
Flashing AC Light yellowminijim First Generation Faults & Fixes 12 Feb 3rd, 2010 12:32 PM
Air Con Button Flashing optimistique1 Maintenance & MINI Care 2 Jun 9th, 2009 08:59 PM
Air-Con / Auto Air-Con / Climate control ??? fitzsimonss First Generation MINI One 13 Apr 19th, 2004 09:44 PM
Flashing A/C light?? Silvercooper First Generation Faults & Fixes 8 Jan 28th, 2004 09:39 PM
Flashing interior light and headlamp flashing like a police car angrybeats First Generation Faults & Fixes 2 Mar 29th, 2002 02:59 AM
