| Mini cooper not turning over first go, but then starts Hi, My 52 cooper is not starting first go, but then i try immediately after it starts just fine Any ideas on what the issue could be, something electrical? Car was remapped a few years ago, no problems since and had some engine work done not long ago (gasket). Was doing it before the engine work however. Any advice would be very helpful before I take it down to the stealers for a look at it. Thanks, James |
| I tried the BP ultimate route, did not help though.. I reset the ECU and it starts first time now. However, after a few days or goes, it goes back to the original problem of not starting first time. I followed the ECU reset guide here : ECU Reset using the speedo diagnostic controls: 1) Hold in your odometer reset button and at the same time turn your key to position 1 2) Release the odometer button and then press it repeatedly until it shows the #19 3) Stop at 19 and the display will go back and forth between "test on" and "off" 4) Push the button when it is on off and the press it repeatedly until you get to #21 5) It will display an option to reset. Press the button and your displays will go blank and your guages will flutter and then the displays will come back on 6) Turn off the key and then your doneand it then works fine, but after goes back to having to start it twice.. Anyone got an idea what could be the problem before i take it down to the Stealers.. Thanks very much James |
| Cam sensor info James, What is a "Cam sensor"? I have the same problem but would like to know a bit more before going to get repaired. My local auto electrician reckons the it does this when the battery is cold. Once the car has been driven a bit, restarts first straight away. Thanks |
| Life Ball MINI 2008 by Agent Provocateur. Auction on eBay starts next week | Paul | General Discussion | 1 | Jun 3rd, 2008 10:57 AM |
| Remote Starts ok for the Mini? | Scott4399 | First Generation MINI Tuning | 7 | Dec 18th, 2005 11:00 PM |
| Mini backlash starts here. Dont pay MSRP! | tomskilv | General Discussion | 65 | Oct 18th, 2005 07:11 AM |
| turning the key cooper fails to start... | paolo19 | First Generation Faults & Fixes | 4 | Dec 24th, 2004 08:29 AM |
