Washer bottle (reservoir) empties completely - MINI Cooper Forum - MINI2 Mini Cooper Forums
View Poll Results: Find a fault one day out of warranty
See if BMW will use some discretion and fix it for free 4 66.67%
Try and blag that it is in warranty 1 16.67%
Use and independent garage to fix it cheaply 0 0%
Fix it your self 3 50.00%
Multiple Choice Poll. Voters: 6. You may not vote on this poll
Old Jul 2nd, 2009, 05:02 PM
Local Time: 12:33 PM
England
United-Kingdom Washer bottle (reservoir) empties completely
What do you do when one day out of warranty and your washer bottle will not fill up? When I tried to fill it up,it emptied on my foot. My local BMW garage would not fix it, even though they checked the key and it was just one day out of warranty. They would not even contact BMW, they would only do this if it involved parts over £100. Thanks to a Haynes manual in a local DIY store I found the solution:
The pipe at the bottom of the reservoir had become detached, to access it remove the front right wheel, unscrew 2 screws at the rear of the wheel arch and 1 screw in front of the jack up point. Move the rear of the wheel arch cover to access the washer bottle and refit the pipe which has become detached. Put everything back in reverse order. Hopefully £ss saved.
Old Jul 2nd, 2009, 05:06 PM
ScottyBoy's Avatar
Obsessive Car Cleaner OCC
Things can be simple if you take a look your self.
Well Done.
Scotty
Old Jul 6th, 2009, 11:09 PM
It's a Mini thing...
Send a message via MSN to Mac_Mini43 Send a message via Skype™ to Mac_Mini43
Local Time: 11:33 AM
United-Kingdom
I had the same problem with my 2006 Mine One. Was a little frustrating to get at, but definately cheaper to have a go yourself. Hose came off again a few days later, but now thanks to a 'cable-tie' I've no more issues with it. Pheww!
Old Jul 7th, 2009, 08:07 AM
still learning
Scotland Male
personally I think it's disgusting that they would not fix it as it was just one day out of warranty.
they could have used some discretion and kept the customer happy.
Old Jul 7th, 2009, 08:21 AM
Paul's Avatar
MINI2 No.1
England Male
I'd have asked BMW/MINI customer service if they could help, then if they said no, just get on and do it.
Thanks for posting a bit of DIY advice too.
Leaking Washer Reservoir Buffster Bird First Generation Faults & Fixes 1 Sep 3rd, 2008 03:13 PM
Washer reservoir dumps straight onto road BoySpring First Generation Faults & Fixes 1 Aug 22nd, 2006 06:52 PM
window washer water reservoir empty mhoutman First Generation Faults & Fixes 27 Feb 2nd, 2004 11:47 AM
Windshield Washer Fluid Reservoir LockjawDavis First Generation Faults & Fixes 8 Feb 20th, 2003 05:32 PM
Larger Windscreen Washer Fluid Reservoir??? GMINI First Generation Faults & Fixes 2 Jan 31st, 2003 08:37 PM
