Valve cover cracked!!!! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 4th, 2009, 02:19 PM
pizmos's Avatar
Local Time: 06:33 AM
United States Male
United-States Valve cover cracked!!!!
Hi all, while replacing my coil pack, I must of over torqued the bolts because it cracked the valve cover in the back. Do you use the rubber grommets again because I used the bolts ALTA supplied,grommets below and above and while tightening it made a snap sound. Bolts were tight comming out and had loctite blue on threads. Stated car and oil blew out a 2" crack below the mounts in the rear.
Called dealer part is $ 289 but not in stock. 1) can I repair the cover with epoxy to temp fix till new cover comes in? 2) how much pressure is the cover under? Doesn't the PVC valve vent the pressure off? I mixed some 2 stage epoxy, after removing oil etc with alcohol, and made a 1/2" patch along the seam of the crack to rebuild the strength up. let it dry and patched again over and wider. Hopeing this will hold. Cannot believe the pressure is that strong to break this patch. Any Ideas or comments?
Cracked rear lamp cover hanoi First Generation Faults & Fixes 3 Nov 3rd, 2011 01:46 PM
Front spotlights, one cracked...new cover? rocker4500 First Generation Faults & Fixes 7 Jan 12th, 2009 01:03 PM
Cracked battery cover :( MCWim First Generation MINI Tuning 0 Nov 26th, 2005 10:37 PM
Has anyone removed their valve cover norm03s First Generation MINI Tuning 5 Feb 15th, 2004 04:49 AM
Valve Cover Gasket Anyone? TonyB First Generation Faults & Fixes 2 Aug 13th, 2003 08:12 PM
