| Metalic rattle/noise COOPER S I hope this as not been covered before! my luck it will have! I had a cooper s in today for a strange metalic sound comming from the right hand side of the car(drivers side...o/s)when you were labouring the engine..creeping away in trafic ect upto 5 mph..(you could also recreate this if you have youre handbrake on and foot brake on whilst letting the clutch out to take up the clutch freeplay)after much diagnosis i traced the rattle to the oil cooler outlet pipe knocking (as the engine moved on its mountings)against the power steering pipe..i had to loosen of the pipe clamps and bend/turn the pipe away from the other power steering pipe so as to give it some clearance.i hope i have added a pic which i thought you guys may be interested in..unless this post as been covered before and im going over old ground...sorry if i am.. cheers |
| Rattle Noise After Engine Off | neverending4181 | Second Generation Faults & Fixes | 0 | Aug 27th, 2007 11:59 PM |
| Plastic Ruler Twang Noise/Rattle | Mini Moo | Second Generation Faults & Fixes | 78 | Aug 20th, 2007 07:24 PM |
| ABS and DSC noise/rattle | leem | First Generation Faults & Fixes | 4 | Jan 26th, 2005 12:22 PM |
| grinding metalic noise at idle | MINIdeeJ | First Generation MINI Cooper S | 2 | Dec 7th, 2004 10:21 AM |
| Rattle/ticking noise from the rear - found it | mikeythemini | First Generation Faults & Fixes | 3 | Sep 3rd, 2003 11:18 AM |
