Eletrical Fault in Pre 8-14-2003 Built MINI Coopers - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 2nd, 2009, 11:46 AM
valnmike's Avatar
Local Time: 07:05 PM
United States Male View valnmike's Chili Red & Black 1st Gen MINI Cooper Profile
This is a follow up to my posts in this thread http://www.mini2.com/forum/first-gen...ad-moment.html
Below is the text of the message I emailed to MINI USA this morning:
I have been experiencing an electrical problem with my MINI. The speedometer cluster goes dead, the flat monitor light flashes, the BATT light comes on and the electric assist on the steering cuts out in turns. I found a Technical Service Bulletin that addresses "one of the following complaints may be encountered:"
The oil pressure warning light is illuminated when the vehicle is in motion but the engine oil level is correct.
Charge indicator Lamp to Illuminate (I have this)
Loss of Power Assisted Steering (I have this)
CAUSE
The engine wiring harness has chafed though against the starter motor heat shield and is causing a short circuit.
PROCEDURE
In event of customer complaint, check wiring harness near the starter motor heat shield and replace it if necessary. The heat shield mist also be replaced if the engine wiring harness is replaced.
NOTE
An improved starter motor heat shield was introduced into production on August 19, 2003:
Part number .......Description
12 41 495 806 ....Starter heat shield;
Refer to EPC .......Engine harness
Defect code 12 51 12 69 00
My car is a 2/14/03 build, so it was prior to the improved heat shield introduction. I have contacted MINI of Towson (MD) where I have taken my car for service. When I asked the service manager why this TSB was never addressed while my car was IN THE SHOP (many times) AND STILL UNDER WARRANTY, he said I had to report the problem first. That approach to customer service is unacceptable and fraudulent.
I have taken my car to an independent repair shop to be evaluated at a cost of $140. They have just confirmed that the battery and alternator are not the problem and that the heat shield has damaged the starter wiring harness. They also inform me that the repair for shield and harness with labor will cost over $900 USD!!!! Approximately $330 is labor and the rest is for BMW MINI parts. That is insane! I request MINI USA participate in the repair of this time bomb that BMW knew has been ticking since before August 19, 2003 when production changes were made to correct this defect. MINI USA should repair this defect as a warranty or recall item. I may be contacted during the day (Mon -Thurs 6 AM - 4 PM Eastern time) at .............
I think I have done a lot to promote the MINI and encourage others to purchase one of their own. If MINI USA is unwilling to assist me in this KNOWN DEFECT I will be one very unhappy MINI owner.
Thank you
-=Mike=- laissez les bons temps rouler
Old Sep 2nd, 2009, 06:35 PM
Jonty06FR's Avatar
Local Time: 01:05 AM
France Male
Please excuse me but I am new to the forum and havent been following this post but.........Is this an international know "defect"? I have just purchased a 05/2003 Cooper S in France and would be interested to know if Im effected?
cheers
Old Sep 2nd, 2009, 06:48 PM
valnmike's Avatar
cheers
If your car's build date is 5 of 2003, I would say it falls within the period before the changes were made in the heat shield. There is only one assembly plant and only one parts stream for all of our cars. Therefore the wiring harness in yours is susceptible to abrasion and shorting out. This abrasion reached the short circuit stage around 75,200 miles for my Cooper.
Tags: , , , , ,
2003 CooperS Vs 2004 CooperS? bazzaric General Discussion 4 Dec 11th, 2008 10:25 PM
Exact Spec of Mini Coopers used in the 2003 Italian Job Bitlord MINI in the Media 4 Jul 7th, 2008 10:52 AM
pre-cat oxygen sensor rich mixture fault 2097 Lizard King First Generation Faults & Fixes 3 May 12th, 2006 08:19 PM
pre 03/02 built Cooper info!!! chris@helix First Generation MINI Tuning 6 Jun 25th, 2002 05:27 PM
