Increased road noise? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 14th, 2009, 02:52 PM
Local Time: 01:55 PM
DIY Increased road noise?
My 02 mini cooper is making alot of road noise, especially at speed (anything over 65mph) its not the quietest car anyway but on the motorway it is excessively loud.
Does anyone have any idea as to the cause of this?
Thanks J
Old Oct 14th, 2009, 03:19 PM
DaFlake's Avatar
MMC Member
Local Time: 08:55 AM
Thanks J
If you ahve run flats that will do it. Even my regular tires are noisy but the runflats were much worse.
Old Oct 14th, 2009, 03:57 PM
No runflats, is there any chance it could be a wheel bearing?
Old Oct 14th, 2009, 04:09 PM
mella yella fella's Avatar
Local Time: 12:55 PM
England Male
Wheel bearings would be the first thing to check, followed by tyres that may be worn unevenly (feathered on edges)
Clubbin' it and Lovin' it
Old Oct 14th, 2009, 05:04 PM
PK5
do you know how to check wheel bearings? if not all you do is go around each wheel to check if there is any excessive wear by pulling and pushing the wheel
Old Oct 14th, 2009, 05:24 PM
Thanks alot for that, will check when it stops raining!
Old Oct 14th, 2009, 05:49 PM
PK5
you may need to check tyre pressures too
Old Oct 14th, 2009, 08:17 PM
England Male
Sorry pk5, but to check a wheel bearing for noise, you need to spin the wheel by hand, and either listen for excessive noise, or even better feel for roughness through the coil spring. A noisy bearing may not always have excessive play
Old Oct 14th, 2009, 09:03 PM
DaFlake's Avatar
MMC Member
Easiest way to do it is drive it and listen for changes in noise when you turn into circles. A trained mechanic can do this easily.
Old Oct 21st, 2009, 11:33 AM
Been to the garage, was a rear wheel bearing, just being replaced now, hopefully this will sort out the noise! thanks for the help
Old May 7th, 2010, 12:02 PM
United-Kingdom
I think I have this issure, but with the front left wheel. Did you take your car back to a dealers ? What was the damage ££££££
I'm wondering if I may be able to make a warranty claim as I have only done 30,000 miles and have a 2008 clubman, so am still in warranty.
hmmmmmmm............maybe worth a try.
Old May 7th, 2010, 12:15 PM
DaFlake's Avatar
MMC Member
Yes, it should be under warranty. Take it in and have it fixed.
Tags: , , , ,
Road noise cbpete Second Generation Faults & Fixes 1 Feb 22nd, 2009 12:47 PM
road noise jd78 General Discussion 11 Jul 30th, 2008 07:14 PM
Road Noise? kand Second Generation MINI Cooper 6 Apr 17th, 2007 08:16 AM
Road noise? mostyn17 First Generation MINI Convertible 7 Feb 21st, 2006 07:05 PM
Road Noise russs99 General Discussion 6 Aug 30th, 2005 09:48 AM
