Front seat not sliding forward - poss fix? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 16th, 2009, 01:46 PM
Local Time: 03:55 PM
Hi,
Had a problem with the passenger seat not sliding forward to let folks into the back of the car. Seat would fold but not move.
Was quoted £150 for new part to fix - seems the broken cable doesn't come by itself but I needed a new set of runners too...
So, I've linked a (bike brake) cable from the original fixing point at the rear of the seat...down and along to near the end of the front release handle and, looping it through a suitable slot in the base of the seat, attached the cable to the release bar (using the release handle fixing screw to grip it).
So tilting the seat back as normal pulls the cable and releases the runners as per the standard mechanism.
Seems to work very well so far
Anyone else tried this and aware of any pit falls? - The release bar sits in its normal position when the seat's in its upright position so no danger of it releasing accidentally.
Tieak
Old Oct 16th, 2009, 06:30 PM
mab01uk's Avatar
Local Time: 01:55 PM
Common problem............your cheap solution sounds like a good idea!
Old Mar 18th, 2012, 08:27 AM
Local Time: 12:55 PM
Wales
Quote: Originally Posted by tieak (original)
Hi,
Tieak
Thanks, I would give this post 99 out of a 100, would of got 100% if you had put a few photos in as well, sounds like a very common problem with the mini as this has happened to the wife's mini recently, and while doing searches for a fix it, and by the way this is a brilliant fix, dose seem to be something that BMW should of sorted by now, but given that you can't just buy a replacement cable but have to buy the complete workings at £150+ no wonder they haven't.
Thanks again for the post tieak, if you have time could would you post a few photos for us "not so mechanically minded" people to have a go at this fix.
Guvs.
Old Mar 18th, 2012, 09:18 AM
mab01uk's Avatar
This link has some photos which may help:
http://www.mini2.com/forum/first-gen...mechanism.html
More on seats here:
Seat Problems & Solutions - Forums
Passenger Seat Not Sliding All The Way Back Cosmo1111 General Discussion 1 Jun 27th, 2008 01:53 PM
How much to fix front seat???? feejb Maintenance & MINI Care 1 Apr 20th, 2008 06:02 PM
Seat sliding too far.. craig5320 Second Generation Faults & Fixes 3 Aug 14th, 2007 09:25 PM
Front Seat - problem with folding / slide forward russ210171 First Generation Faults & Fixes 6 Apr 12th, 2006 06:38 AM
Front seat getting stuck while tilted forward? MiniMan7 First Generation Faults & Fixes 16 Mar 25th, 2006 09:49 AM
