| mini one (01reg) - headlight fault hi guys, have a mini one 2001.. the drivers side dipped beam bulb went the other day and upon replacing i now have the problem that even with the ignition switched off the bulb will now not turn off unless removed. is this a common fault? it is not a parking light either i have checked this. If anyone can advise i would be very grateful. thanks rowan |
| Tags: headlights, lights |
| REAR WINDOW SHATTERING FAULT - dealers aware of fault | Mini Virgin | First Generation MINI Convertible | 161 | Feb 14th, 2012 12:02 PM |
| Xenon Headlight Fault, Always on pointing at the ground | rhenium188 | First Generation Faults & Fixes | 0 | May 6th, 2009 01:59 AM |
| Intermittent Headlight Fault | mtuk | First Generation Faults & Fixes | 2 | Oct 7th, 2004 04:20 PM |
| Fault After Fault - At Wits End! | COOPERUK | First Generation Faults & Fixes | 6 | Oct 13th, 2003 12:03 PM |
| Non MINI headlight question.... | Paul | First Generation MINI Exterior | 5 | Feb 17th, 2002 11:36 AM |
